HRM clip, CD bound.....
dogears
Post by dogears »
I recorded this solo yesterday for the track Bionic Hillbilly by Hectic Watermelon www.hecticwatermelon.com Originally I was to get one chorus, about 16 seconds. It was extended to 2 choruses. The problem I had was deciding whether to keep to the frantic nature of the solo section and come out guns blazing. I wound up playing MUCHO notes...
Amp is the Glaswerks SOD 50. Baker RF on bridge. SM57 mic. Emmy Red White and Blue.
http://www.scottlernermusic.com/music/Bionic2pass1.MP3
After recording, I made some tweaks for the much better. I replaced the JJ 6L6 outputs (which were not intentionally up at 46ma!!!) with Winged C tubes at 38ma. I tweaked my HRM a little and the post OD bleed. I added a 12pf bright cap on the OD master. There was none on the master for this clip.I also raised the Dumbleator recovery amp plate from 177v to 192v. It was noticeable and an improvement I think. And some other general neatening things.
Thanks for the feedback!
EDIT: I just recorded this NON HRM take that I liek more both tonally and playing. I'll do some HRM clips later. It is also sounding much better now that I made the most recent changes.
http://www.scottlernermusic.com/glas/Bi ... mobass.MP3
oldmacman
Re: HRM clip, CD bound.....
Post by oldmacman »
I like the attack - each note is distinct and clear. Very tight-sounding.
You're right - that is MUCHÍSIMO notes!
Normster
Post by Normster »
I like it! Something about that last lick that strikes a chord with me.
Robert
Post by Robert »
Wonderful cut Scott! Clear and articulate notes with that nice Dumble sing in the highs. It will be nice to hear your solo in the context of the entire piece. The description of your tweaks is also greatly appreciated.
I just got a 2X12 cab I need to populate with some speakers. Looks like you still favor the Red,White,Blues.
Bob-I
Post by Bob-I »
It's difficult to tell if the frantic/nervous nature of this solo fits in the piece without hearing the rest of the piece. Plus it's hard to decide with my head spinning like this. :o
Amazing playing Scott, kinda reminds me of Early Les Paul, pre Mary Ford/frantic solo's. Melodic and wild at the same time.
dogears
New Solo with NO HRM
Post by dogears »
What do you guys think of this NON HRM solo I just did? I like the tone and I think the playing is much more focused and lyrical.....
pedro
Post by pedro »
I'm thinking out loud here - but sometimes its best to react to the sounds without too much reflection......
... the NON HRM is "wider" and a tad smoother to me.
The HRM sounds "narrower" and more "aimed".
I like the slightly looser , silky feel of the NON HRM clip.
I also like the slippier opening phrase on the second clip.
Its so subjective - like fine wine tasting - but great to hear these clips Scott.
2nd clip for me ....Both are bloody great though.
cheers
Pete C
oldmacman
Post by oldmacman »
IMHO, the HRM solo fits better here. Much more authoritative - sits better in the mix.
ElectronAvalanche
Post by ElectronAvalanche »
Hi Scott,
very nice clip! Maybe a bit too many notes for me :D I am just a very slow player. And could never play what you played there!!
I really liked the first clip the best.
Dominik
dobbhill
Post by dobbhill »
Dogears, please explain your "post OD beleed" arrangement. I'm very curious.
Thanks, Dave
dogears
Post by dogears »
Just put a 250k pot and .001uf cap in series from the V2b plate to ground. Works on both HRM and non HRM. I recommend a 47k tail to ground as well.... I like nonHRM set around 140k resistance and HRM set at around 180-200k.
dobbhill wrote:Dogears, please explain your "post OD beleed" arrangement. I'm very curious.
Thanks, Dave
dobbhill
Post by dobbhill »
I use that arrangement in a "pre-OD" but have not tried "post-OD". I'll have to try that and compare.
Thanks, D
dobbhill
Post by dobbhill »
I installed a switch that puts a high frequency trim (0.01 cap into a 100k pot to ground) before or after the OD section. The difference is not subtle. Using pre-OD, the sound is more raw and grindy, if that makes sense. Using it as a post-OD control makes the sound more fluffy and furry.
I like it both ways.
It does affect the gain. I was wondering if anyone had a suggestion as to whether to put the control in parallel with the OD input trim or after the input trim (180k into 100k pot)?
Once again, thanks Dogears for your suggestions and guidance. I appreciate having you here to share your experience and opinions.
D
