I there any reason why simple milk plexiglass pieces couldn't be used for the boards in this build... say 3/16th
Ange
Dumbleator materials
- Luthierwnc
Re: Dumbleator materials
Also, 3/16" is too thick for standard lugs and turrets. They have to stick out far enough on the other side to swage the ends. Hoffman and McMaster have garolite pretty cheap. It is murder on saw blades though. Skip
stick with tried and true
I will stay with the standard materials. Thanks
- Funkalicousgroove
Keystone makes eyelets up to 1/4" deep, so I see no problem there, you should get the material data sheet and look at the dielectric strength, flame retardant properties, and melting temp, etc.- I think you could make it work if you really want to-
- glasman
The first amp I ever built was on .25" plexiglass from the local ACE store. I used escureon pins (brass) and mounted pushed them into holes I drilled in the plexiglass.
It worked, put the plexiglass did melt with enough heat. The board is still hanging on my wall as a testament to how not to do things
Gary
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- glasman
Still had a picture of that amp (many times rebuilt).
[img:474:232]http://www.glaswerks.com/bottomview.jpg[/img]
www.glaswerks.com
www.glaswerks.com
