I'm considering what to build after I finish up with this Trinity OSD kit, I might have to pick up one of your chassis, boards, and cab. Those look fantastic!
I've always wanted to do a 50W #183, but have always wondered what to do about the trannies. As the original #183 used out of spec Twin iron running a quad of EL34's, surely if you did a 50W version you would have to factor in the out of 'specness', to get the operating characteristics right. Taylor, did you use a Classic Tone Bassman OT to run your EL34's, and a custom Heyboer? If so, could you tell us what you requested for the heater current capability etc?
Nicely done Taylor! On the relay supply using the 5VAC and a FWB, that has to be right on the ragged edge of having enough headroom for the regulator, no?
martin manning wrote: ↑Sat Apr 07, 2018 9:48 am
Seems to hold up ok...I've been using this setup for awhile without issues. I think this might be the first build thread using the boards - thanks again for your contribution!!! I obviously didn't use them all...but they are killer
Last edited by amplifiednation on Sat Apr 07, 2018 1:02 pm, edited 1 time in total.
M Fowler wrote: ↑Sat Apr 07, 2018 12:42 pm
Taylor love the wiring, boards and overall neatness.
I concur!
Taylor, what gauge/type wires do you tend to use for your builds? Your lead dress and soldering always looks extremely neat!
- Matt J.
22-24ga stranded Teflon for signal and relay wiring.
20ga for preamp heaters
18ga for power heaters
I use a lot of the transformer clippings too!
I use two kinds of solder on these. I really like the clean look of Kester 245 but the flux isn’t aggressive enough to solder the back of the pots. I use Kester 44 for that, and still add more flux!
I concur!
- Matt J.
Nice! Thanks for the tip on the solder. I'll have to pick up some. I'm running low on my general supply as it is.
Expect a PM soon on buying a chassis, boards, and cab from you! This work is inspiring!
BTW - Are those Koa Speer CF resistors you used in the signal chain?
amplifiednation wrote: ↑Sat Apr 07, 2018 12:59 pm
I forgot how much 'tone lives on' without built in reverb attenuation. The amp sounds incredible
I like the #60 mixer and attenuation way better for that rather than the Two Rock style Reverb after the master (#60 simulate an half way master as part of the mixer/atténuation network).
Awesome build as always.
Considering you use 250k drive and level pots along with 15n OD1 cap, do you have any excess bass on the lower strings, especially on OD without PAB ?
