Manzamp!
amplifiednation
Re: Manzamp!
That is just too cool. I feel like you were even able to clone the lighting of that picture!
Did you get the handle mounted? Did the spacing of the chassis opening match up with the Manzamp photo?
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
Re: Manzamp!
Yes the top came out perfect also.amplifiednation wrote:That is just too cool. I feel like you were even able to clone the lighting of that picture!
[img
"You feel like you're floating on a football field filled with marshmallows." -Dumble
Re: Manzamp!
Like these?Aaron wrote: Any photos of the circuit board?
Aaron
[img
[img
Re: Manzamp!
Image re-loaded.Mark wrote:The photo disappeared?
amplifiednation
Re: Manzamp!
Man...we really did do a good job!!!ic-racer wrote:Yes the top came out perfect also.amplifiednation wrote:That is just too cool. I feel like you were even able to clone the lighting of that picture!
[img768]http://img.photobucket.com/albums/v670/ ... ampTop.jpg[/img]
thanks again!
Amplified Nation
@ampnation
@ampnation
Re: Manzamp!
I have a low level hum. It seems to come from the cathode follower. The cathode is at 184 volts. I suspect the hum is from cathode-to-heater voltage differential. I'll try swapping tubes around and see if I can find one that minimizes it.
Re: Manzamp!
I finally got around to re-building my little recording studio. Now I use an iPad and Behringer is202.
This is the first thing I recorded with that setup. Manzamp in its 4x10 cabinet with the 4 MusicMan speakers and a Les Paul Standard.
https://www.youtube.com/watch?v=jRGgZZ7jjkk
Re: Manzamp!
WOW!!
That sounds amazingly fantastic! Beautiful touch sensitive tone & excellent
playing. It's been a while since I've heard an amp build that sounded so sweet!
Thank you for sharing your success!
With respect, 10thtx
- ElectronAvalanche
Re: Manzamp!
Great amp and clips IC!
I really impressed by your work. Sadly it seems to inspire me....
Now I also need to build a Manzamp...
So what is next? Dumbleland? Pentode Amp? Looking forward to any new build blog from you.
Electron
Electron
Re: Manzamp!
Great tone! Well done.
Re: Manzamp!
Sounds wonderful. Both your playing and building skills are superb.
Re: Manzamp!
Just out of curiousity, ........... do you have any plans on building another one but with a dumblish OD sections also?
with respect, 10thtx
