Manzamp!
sepulchre
Re: Manzamp!
Post by sepulchre »
That's bloody amazing, IC! From photo to Fine amp -Superb work!
Activax Amplification
amplifiednation
Re: Manzamp!
Post by amplifiednation »
That is just too cool. I feel like you were even able to clone the lighting of that picture!
Did you get the handle mounted? Did the spacing of the chassis opening match up with the Manzamp photo?
Amplified Nation
www.amplifiednation.com
@ampnation
ic-racer
Re: Manzamp!
Post by ic-racer »
amplifiednation wrote:That is just too cool. I feel like you were even able to clone the lighting of that picture!
Yes the top came out perfect also.
[img:1024:768]http://img.photobucket.com/albums/v670/ ... ampTop.jpg[/img]
"You feel like you're floating on a football field filled with marshmallows." -Dumble
Re: Manzamp!
Post by Mark »
The photo disappeared?
Yours Sincerely
Mark Abbott
ic-racer
Re: Manzamp!
Post by ic-racer »
Aaron wrote: Any photos of the circuit board?
Aaron
Like these?
[img:1022:605]http://img.photobucket.com/albums/v670/ ... mplete.jpg[/img]
[img:1024:768]http://img.photobucket.com/albums/v670/ ... ile-71.jpg[/img]
ic-racer
Re: Manzamp!
Post by ic-racer »
Mark wrote:The photo disappeared?
Image re-loaded.
amplifiednation
Re: Manzamp!
Man...we really did do a good job!!!
thanks again!
Amplified Nation
@ampnation
ic-racer
Re: Manzamp!
Post by ic-racer »
I have a low level hum. It seems to come from the cathode follower. The cathode is at 184 volts. I suspect the hum is from cathode-to-heater voltage differential. I'll try swapping tubes around and see if I can find one that minimizes it.
ic-racer
Re: Manzamp!
Post by ic-racer »
I finally got around to re-building my little recording studio. Now I use an iPad and Behringer is202.
This is the first thing I recorded with that setup. Manzamp in its 4x10 cabinet with the 4 MusicMan speakers and a Les Paul Standard.
https://www.youtube.com/watch?v=jRGgZZ7jjkk
10thTx
Re: Manzamp!
Post by 10thTx »
WOW!!
That sounds amazingly fantastic! Beautiful touch sensitive tone & excellent
playing. It's been a while since I've heard an amp build that sounded so sweet!
Thank you for sharing your success!
With respect, 10thtx
ElectronAvalanche
Re: Manzamp!
Post by ElectronAvalanche »
Great amp and clips IC!
I really impressed by your work. Sadly it seems to inspire me.... :D :D :shock:
Now I also need to build a Manzamp... ;-)
So what is next? Dumbleland? Pentode Amp? Looking forward to any new build blog from you.
Electron
Re: Manzamp!
Post by Mark »
Great playing and a lovely sounding amp.
Yours Sincerely
Mark Abbott
NickC
Re: Manzamp!
Post by NickC »
Great tone! Well done. 8)
CHIP
Re: Manzamp!
Post by CHIP »
Sounds wonderful. Both your playing and building skills are superb.
10thTx
Re: Manzamp!
Post by 10thTx »
Just out of curiousity, ........... do you have any plans on building another one but with a dumblish OD sections also?
with respect, 10thtx
