where can i buy some sheilding to put on the bottom/ inside of my headshell.  similar to the stuff used in the komets would be great.
thanks
bill
						cabinet internal shielding
- Sonny ReVerb
Re: cabinet internal shielding
I use aluminum flashing sold at your local hardware store. Cut to size and attach it with a shot of Super 77 spray adhesive. Seems to hold up pretty well. It's the same material as the chassis, so it should provide comparable shielding. Definitely higher quality than the 'metallic' contact paper they put in my Z28.
If you want to go the cheaper route, you can buy aluminum HVAC tape from Lowe's or Home Depot.  Just be sure to get the uncoated kind.
Another option is hobby stores that sell rolled up sheets of copper for copper art.  Easy to cut with scissors.  You can glue or staple it.  Copper is a GREAT shield.
Me: Just one more...
cool.  ill try them out.  thanks
is there anywhere to order a roll of tape thats like 1' wide.  instead of covering it with 1 inch strips?
Fender used window screen, w/edges folded twice under to eliminate edge fraying.  It works great!, and you don't need 100% shielding to tame the noise.
...provided you can still find Aluminum (vs. plastic) window screen!
I like the brass/copper foil, which I've used with success, but it's gotten scarce at the local mega-craft stores recently.
I've also used the HVAC sheet tin (cheap and widely available, but not amenable to normal staple guns).
--mark
--mark
That's what I use. I get aluminum screen at the local hardware store.BobW wrote:Fender used window screen, w/edges folded twice under to eliminate edge fraying. It works great!, and you don't need 100% shielding to tame the noise.
