Do Non-Inductive WW Resistors Matter In Git Amps?
rp
Post by rp »
... in the usual places where one might stick a ww - output tubes, power string? And while we are at it - on the power tube screen grids? Do 2W cc's have any advantage over MOs, CFs, WW, especially on power tube G2?
I know all those old, ubiquitous, sandbox types weren't non-inductive and were fine. But, as I must order up some parts I'm just curious if it is at least theoretically better.
Or, all good, don't worry, be happy?
tonewood
Re: Do Non-Inductive WW Resistors Matter In Git Amps?
Post by tonewood »
I'm thinking that non inductive resistors are good at high impedance places that don't have high voltages across them like the grids. (read that on one of the good sites around here, don't remember which one) Not sure about G2 though since they aren't so far from AC ground. I'll be watching for a good answer to that...
Firestorm
Post by Firestorm »
IIRC, the amount of inductance in a WW is so small that it doesn't really make any difference in an audio frequency amp.
Aren't most if not all wire wound resistors inductive due to the nature of their construction?
VacuumVoodoo
Post by VacuumVoodoo »
Structo wrote:Aren't most if not all wire wound resistors inductive due to the nature of their construction?
No. Noninductive ww resistors are made using bifilar winding or 2-layered winding with 2nd layer wound in opposite direction to the 1st.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Ah, thanks Aleks. :)
katopan
Post by katopan »
Firestorm wrote:IIRC, the amount of inductance in a WW is so small that it doesn't really make any difference in an audio frequency amp.
That's what I was thinking, although I've never gone and measured how much inductance they have.
