component tolerance and type
Can some of you kind folks take a look at the layout and give me your educated guess,s on what the resistor marked in red would want to be, many thanks
diagrammatiks
Re: component tolerance and type
your colors didn't get saved.
corrected now loldiagrammatiks wrote:your colors didn't get saved.
diagrammatiks
here take a look at this black cat
[img
685]http://s339.photobucket.com/albums/n441 ... C_0117.jpg[/img]
Samson's amps pretty much use 1-2watt carbon comps for everything except the power supply.
[img
Any opinion on the diodes used on the tube and soldo state rectifier?
uf4007s
diagrammatiks
ya uf4007s although any soft recovery rectifier would do. 1000v 1a should be enough.jestaudio wrote:Any opinion on the diodes used on the tube and soldo state rectifier?
