z original prescription schematic or info
funkmeblue
anyone have any info. To be honest, I want to build one similiar.
Re: z original prescription schematic or info
Since the amp was discontinued some time ago, why don't you try emailing them for the schem?
Mike Zaite might jump in here to help talk about his amp I hope.
The original didn't have the boost switch I believe and the next generation the RxES came with toggle switch boost and later to foot switch.
Doc noted on previous post:
Sorry that was the Mazerati
https://tubeamparchive.com/viewtopic.ph ... highlight=
12Ax7 into an EF86 second postion, 12AX7 PI into four EL84.
290-0-290 PT 250mA and 4k OT 40w rating
The RX has a full EQ and a EF-86 as a recovery stage. The 3 dB boost runs on the EF-86, added by-pass cap to the cathode, for a nice FS lead boost. It uses negative feedback which keeps the amp tight great for humbuckers. Also it uses a split load cathode bias so two differant pairs of EL-84's can be installed.
I did find this old review for a few more clues
http://www.harpamps.com/micKamps/Dr-Z-Prescription.html
funkmeblue
ya, I read that old review. I'm guessing a souped up plexi circuit with el84's and conjunctive filtering like the ghia. The expand switch I would guess adds a bypass cap. the old rx
1/2 V1 is used like the Liverpool then TMB, volume into EF86 V2.
The rest is like an AC30 or Liverpool. I don't see any conjunctive filter.
25uf cap switched for boost.
That's what I reckon the new ES prescription is like. But the old prescription doesn't have an EF86, just 3 x 12AX7sM Fowler wrote:1/2 V1 is used like the Liverpool then TMB, volume into EF86 V2.
OK I see that old one now, it has a DPDT switch off the volume control like the Liverpool wired like Colossal posted rather then TW style, 12Ax7 v2 full tone stack a spdt switching out large looking cap probably still 25uf
This is not split load bias like new ones either.
Hey guys my dad was taken into Hospice care this week.
He has renal failure as well as a few other ailments.
I will be out of pocket for a week or so.
Mark I would be happy to get you an assembly drawing of the Original RX
for you to post.
E-mail or call me in a couple of weeks.
Z
for you to post.
Z
Mike very sorry to hear the news regarding your father my prayers are with you and your family.
I'll give you some time before I contact you.
Dr. Z, I know what you are going thru as I have End Stage Renal failure also. The doctors are doing a wonderful job of keeping me alive day by day. I have had a few close calls but just try to live each day to the fullest. I build amps to take my mind off of my medical situation. My father is borderline with the onset of Renal Failure. My prayers will be with you and your DadDR.Z wrote:Hey guys my dad was taken into Hospice care this week.
for you to post.
Z
mcrracer
I'll be thinking about you too in my prayers.
So sorry to hear about your ailments guys.
You certainly will be in my prayers as well.
Hey! wow!! DR.Z!!!
Thank you very much for offering your old schematic up for analysis. That is very generous of you.
I hope your Dad's stay in hospital is as pleasant as can be under the circumstances
Dr Z noted his father is in Hospice care at this time for end stage renal failure.
