And the name is to die for
Ceriatone Dildo-lator to be released soon
i have confermation that Ceriatone is finally releasing a tube version of the kleinulator. Can't wait to see it and hear it. I still havent tried a umbleator with any of my ODS amps as there is no source to buy them at a reasonable price until now
Re: Ceriatone Dildo-lator to be released soon
Lets hope your wife doesn't borrow it from you all the time
[img:600:450]http://www.ceriatone.com/images/complet ... or/b2B.jpg[/img]
Seems to have little resemblance to the real deal...
That's the old model with JFETs, the TS is saying that will be releasing a tube version soon.
Where did you find that info?
Nik at Ceriatone he's pretty open with the projects he's working on and he answers ALL emails within 24 hours. great guyStructo wrote:![]()
Nik told me today he is just waiting on parts before he releases the loop.
Hi,
any news about the Dildo-lator?
- FUCHSAUDIO
Fuchs/Plush has been making a tube loop and a tube loop with a built in reverb for almost 2-years, both quite reasonable. So has Brownnote, Red Plate, and others as well.JD0x0 wrote:i have confermation that Ceriatone is finally releasing a tube version of the kleinulator. Can't wait to see it and hear it. I still havent tried a umbleator with any of my ODS amps as there is no source to buy them at a reasonable price until now
yes i relized that. the Plush pedal looks sweet but i'm not a huge fan of reverb or digital effects (the digital reverb) also ive never had a chance to try it out in personFUCHSAUDIO wrote:Fuchs/Plush has been making a tube loop and a tube loop with a built in reverb for almost 2-years, both quite reasonable. So has Brownnote, Red Plate, and others as well.JD0x0 wrote:i have confermation that Ceriatone is finally releasing a tube version of the kleinulator. Can't wait to see it and hear it. I still havent tried a umbleator with any of my ODS amps as there is no source to buy them at a reasonable price until now
And regretably i still havent found a Fuchs ODS to try.
from what ive seen most dlator effects have been quite expensive with the exception of your pedal, Andy, and the klein from ceriatone.
Andy, im going to have to drive down to NJ one day and give all your amps a go, they sound beautiful
- FUCHSAUDIO
Thanks for the kind words. Don't fear digital....lol. I have studios and sound guys using the Verbrator in place of many hallowed processors and effects.
It will be interesting to see the price point, features, and the inspiration used for the new C-tone device.
I think it is kind of juvenile to name that tube loop that way.
Hopefully Nik will choose a different name.
Not that I am some kind of puritan, I just think it is in poor taste.
Thumbs down for the name.
vibratoking
Andy,
What is the difference between the Plush tube FX loop and the loop that is built into your ODS amp? The amp has an active FX loop already, so no need for the Plush device, if I understand correctly?
- FUCHSAUDIO
It's the same loop as the ODS in all respects: series/parallel, return trim, send and return level controls, except it runs on a switch mode power supply. It runs on an external 9-VDC adaptor, while the 12AX7 tube runs on regulated 300-V and 6VDC filaments. Both models same circuits. The Verbrator (tm) and Tube Fx Loop (r) are the same circuit. The Verbrator (tm) reverb is fully out of circuit when the reverb is turned off.
If you have an ODS (c), you won't need one.
If you have an amp with a passive loop (or patch jacks) i.e.: Two-Rock, Bludo, Brown Note, Ceriatone, Dumble, etc etc, you should use one when using outboard effects for maximum fidelity.
