Power Transformer sizing..
dehughes
Post by dehughes »
So, I ordered the following power transformer from Heyboer today:
Primary: 120 Volts
Hi Volt: 270-0-270 Volts @ 120 mAmp
5 Volt rated @ 3 Amps
6.3v: Center tapped (3.15-0-3.15), rated @ 5 Amps
So, is 120ma going to be enough for my amp? I'm having second thoughts on the PT build.... The 6V6s are cathode biased and drawing about 74ma or so for the pair, and I figure the two 12AX7s are drawing maybe a couple ma for the both of them (PI and input). As well, the 6SN7 is biased pretty cold (preamp channel, 117v plates and 4.5v across a 2k7 Rk), so it shouldn't be drawing too much. I just don't want to build the PT too small and end up regretting it later...as I don't know how much "overbuilding" is required to have a properly functioning PT.
I wager I could still have them build it a bit bigger (doubt they've started on it yet), but then, I find that I like "right" sized transformers (r.e., not too big) all things being equal in an amp. My goal for this amp isn't to get it big fat and clean so much as clear but squishy under the right circumstances...without frying anything.
Thoughts?
Tempus edax rerum
dartanion
Re: Power Transformer sizing..
Post by dartanion »
I think that the PT you specify should work fine.
dehughes
Post by dehughes »
dartanion wrote:I think that the PT you specify should work fine.
Cool. Thanks man. I'm just working off of what you and tonestack told me on the other thread, but got kinda freaked when I saw a bunch of 150ma-ish PTs being run with 6V6 pair amps...especially when I'm running a 6SN7 in the preamp of mine. Still, when I do the math, I keep landing under 100ma for everything, and that's with the 6V6s biased into Class A...
Tempus edax rerum
David Root
Post by David Root »
Just curious, why so low Vp on the 6SN7? Is that one triode or both in parallel? 6SN7 likes current.
Having said that I have an amp with a 6SN7 in parallel pulling less than 3 mA that made a big positive difference in the overall gain architecture because of the tube's huge clean headroom. Vp 174V.
dehughes
Post by dehughes »
David Root wrote:Just curious, why so low Vp on the 6SN7? Is that one triode or both in parallel? 6SN7 likes current.
Dunno...that's where it landed when strung in the same spot as the 12AX7 channel. I started trying to copy the Komet Constellation 6SN7 preamp, but that kinda went away when I realized it didn't mesh well with the 6G3 preamp setup. As of now I have the 6SN7 running with the triodes in parallel and acting as a substitute for one of the 6G3 12AX7 channels.
I was thinking of running the B+ to the 6SN7 from an earlier stage in the rail in order to get higher Vp. The current B+ setup is a vestigial remnant from my prior desire to Komet-ize the preamp. I'm not set on the current form of things...have you any suggestions for "ideal" 6SN7 values/voltages/setup?
Tempus edax rerum
