You can cross reference also when shopping for OPT, CEdist and few others
gives tranny info for the products they carry. Hammond transformers has
good ballpark data for its product too.
The quick and dirty way of determining primary impedance is: (Va * Va) / W Regardless of what the data sheets say, there is no way on God's green earth that a 2 x EL84 amp operating with 300VDC on the plates is going to deliver 17W to the load with a 1000-to-1 impedance ratio (8K primary into an 8 Ohm load), as (300 x 300) / 8K ~=11W (Granted, impedance rises and falls with respect to frequency, but it is not going to fall that much on average). The proper primary impedance for a 17W 2xEL84 amp with 300V on the plates is ~=5.3K into and 8 Ohm load (or an impedance ratio of ~663 to 1) . That's why the primary impedance on vintage VOX AC15s is in the low 6K range.
It's not rocket science. Think about the problem in terms of power.
Power (W) = Voltage (E) x Current (I)
As I = E / R, W = E x E / R (or E^2 / R, where "^" is used to denote raised to the power of).
In the case of an output transformer, we are dealing with Z instead of R; therefore, W = E^2 / Z. We can pump as much current as we like into the output stage; however, the amount delivered to the load is bounded by the reflected impedance of the load and the efficiency of the output transformer.
Now, let's look at the problem from the secondary end of the output transformer. An 8K-to-8 ohm output transformer has an impedance ratio of 1000-to-1. Impedance ratio is the square of the voltage ratio. We have a voltage ratio of ~31.6-to-1; therefore, with three hundred volts on the plates, we have a secondary voltage of 300 / 31.6 ~= 9.486833 volts. Plugging this voltage level into the power equation shown above gives us 9.486833 x 9.486833 / 8 ~= 11.25W.
The equation that I have outlined above sets the upper limit for the amount of power that can be delivered to a load. It does not set the optimal primary impedance for a particular tube or set of tubes. The selected operating class and point must be capable of delivering the desired amount of power. A Champ has a 7K-to-4 Ohm output transformer. However, single-ended amps are only 25% efficient; thus, 7K is more than low enough to the deliver 3-4 Watts that these amps produce.
