2w Sub Miniature Express
Re: 2w Sub Miniature Express
I've been using an Eminence Private Jack in a cab built by Bob Burt. The PJ sensitivity is 101. Good, broad spectrum.
Plan next to drop in an Eminence Wizard. It's more effecient, at 103. A bit more treble, with a tighter bottom.
BTW, the BB cab is one I spec'ed for him to build. It replicates the precise dimensions and ports of a Shiva combo cab.
I've heard a lot of good things about those Burt cabs.
Is your cab a barn pine wood cab?
He built one out of really old barn wood for a friend of mine.
Looks and sounds great!
It's tolex-covered new pine. Wanted to replicate all the characteristics of the Shiva cab. Was very tempted tho. His work is just outstanding.
The clips help & I hear a lot of potential in those clips BTW!!
just sorted out some parallel wiring for two newish 16 ohm 12" Greenbacks in epiphone Valve Junior extension cabinets. Not bad at all - an improvement on the V30 in an open backed cab. Impressive amount of bass in this amp! Seems almost ridiculous for its size.
So am I understanding you right? You went from a v30 open back to a couple of closed back 1 x 12s with greenbacks?gary wrote:just sorted out some parallel wiring for two newish 16 ohm 12" Greenbacks in epiphone Valve Junior extension cabinets. Not bad at all - an improvement on the V30 in an open backed cab. Impressive amount of bass in this amp! Seems almost ridiculous for its size.
I have a Marshall 1936V which has 2 x 12 V30s and think it sounds great with my Lil Devil. I also played it through a 1x10 Celestion V10-40 Silver Series mounted in a Little Lanilei closed back cab by Songworks. Sounds weak but better for late night practice with lower volume.gary wrote:just sorted out some parallel wiring for two newish 16 ohm 12" Greenbacks in epiphone Valve Junior extension cabinets. Not bad at all - an improvement on the V30 in an open backed cab. Impressive amount of bass in this amp! Seems almost ridiculous for its size.
UR12 wrote:So am I understanding you right? You went from a v30 open back to a couple of closed back 1 x 12s with greenbacks?gary wrote:just sorted out some parallel wiring for two newish 16 ohm 12" Greenbacks in epiphone Valve Junior extension cabinets. Not bad at all - an improvement on the V30 in an open backed cab. Impressive amount of bass in this amp! Seems almost ridiculous for its size.
The epiphone 1x12 cabs have a 6" square cut-out on the back panel, so they're not fully closed. I just spliced a couple of home-made speaker cables together to parallel the two 16 ohm cabs.
Is it possible to mod this amplifier somehow so it can also accept 16Ohm speakers?
Not without changing the OT. You can safely run a 16 ohm speaker on the amp. 4 ohm might be a bit much but 16 ohm should work without damaging the amp.MCK wrote:Is it possible to mod this amplifier somehow so it can also accept 16Ohm speakers?
Super! Thanks for letting me know. My V30's measure about 14Ohms on my Fluke anyways so closer to 8 than 16.
You are measuring DC resistance of the speaker coil when you measure it with an ohm meter. That will be a little bit different than the AC impedance of the speaker. For example, a speaker with a 4 ohm impedance will usually measure about 3.2 ohms resistance. A 8 ohm speaker will measure about 6 ohms resistance and a 16 ohm , as you found out will measure about 14 ohms.MCK wrote:Super! Thanks for letting me know. My V30's measure about 14Ohms on my Fluke anyways so closer to 8 than 16.
Great to know my V30's are regulation 16Ohms then! I'm educated once again. Thanks much! You should have charged me extra for all the knowledge!
Does the kit or production amp come in a combo version, where the chassis would be flipped around with the tubes and iron hanging from the bottom?
No, I had plans for a combo version but after trying a couple of prototypes I decided to do a 1x 12 cab and the head. I had the chassis mounted like the old Fender tweed amps (verticle) with the controls on the top back of the cab.dayn wrote:Does the kit or production amp come in a combo version, where the chassis would be flipped around with the tubes and iron hanging from the bottom?
