Aren't these cute!
drhulsey
Aren't these cute!
Post by drhulsey »
I got a quantity of these with some surplus wire.
They have a 3/8" ID on the ring, and the lug is 19/32" long from the bend.
The lug is not nearly as long as the ones we've seen.
Although the length of the lug would be long enough for smaller pots,
the ID is too big.
Tim
David Root
Re: Aren't these cute!
Post by David Root »
They are indeed. Never seen those before. What were they intended to do?
mark enger
Post by mark enger »
looks good for quick ground lug. i happend on a batch something like that and they have come in handy mark
Aren't those typically used for running a ground buss through above or below the pots?
Tubetwang
Post by Tubetwang »
I recognise those...
Pacemaker washers... :roll:
drhulsey
Post by drhulsey »
Tubetwang wrote: ...Pacemaker washers...
That's not how you clean pacemakers :roll:
David Root wrote:...What were they intended to do?
They're too small to use on full sized pots too big for the small pots.
It's obviously a grounding lug that fits over some panel mounted component.
The ID is way larger than the usual ground lug.
It may have been a custom item.
I'll add it to my long list of things I've not seen before.
Tim
Andy Le Blanc
Post by Andy Le Blanc »
I have a small pile of the larger of those for JAN carbon pots. Old rotary switches
have a bushing that is that size, some probe jacks and telephone hardware
was that size.
lazymaryamps
stoo
Post by stoo »
Oh Geez! don't bend that roach clip!! :wink:
Stew
Did we ever find the correct pot solder lugs from Mouser? I saw tht Ron Worley had shown a part number previously which were not correct.
I have a book from Craig Anderton, Musicians projects and he makes reference of these solder lugs for potentiometers with a drawer very similair to yours but not as cute Doc.
drhulsey
Post by drhulsey »
M Fowler wrote:Did we ever find the correct pot solder lugs from Mouser?
It's not Mouser, but Golden O on ebay has them listed as we speak:
http://cgi.ebay.com/100-Centralab-Pote ... rkparms=|
Digikey has the double-armed lug which is the same size, but with two arms :shock:
Tim
