Just finished my HRM build. It is based on s3988009 with a few minor differences. I will detail the spec below. I've used a 4PDT relay for switching channels and PAB simultaneously. The good news is there are no noises, hums, buzzes, switching noise etc and I acheived this with only 2 sheilded cables in the entire build. the not so good news is that the clean sound lacks 'sheen' and gets farty at higher 'gain' settings and the overdrive tone is rather fizzy and has upper mid honk that reminds me of a Boss HM2 pedal
Here's the spec:
Chassis is from a twin reverb with an original BF Bassman PT and a Weber EL34 45W OT.
Tubes are all NOS Mullards.
Power supply is currently using the Fender style series 220uF's on the plates and then single 22uF's. The dropping resistors are similar to the schematic. I've used the BF Bassman choke.
V1 plates are around 200V, V2 around 220V and V3 around 300V. The EL34 Screens are at 438V and plates at 441V.
5.1K Grid resistors on EL34's (seems a little high to me for 34's).
All pots are as the schematic.
Tone control is skyliner with R/J and mid boost, PAB when in OD
47pF Bright on the clean master.
CL1 cathode 5uF/3.3K
CL1 Plate 220K Dale MF
1000pF/500pF treble, 0.01 mid, 0.1 bass (the mid control seems a little unresponsive ??)
CL2 Grid 220k/470pF
CL2 cathode 5uF/2.2K
CL2 Plate 150K Dale MF
Coupling Cap .047uF
No local feedback
OD Entrance 470K/47pF - 200K - 25K Trim - 4.7K Tail
OD1 Grid - 68K
OD1 Cathode 5uF/2.7K
OD1 Plate 180K Dale MF
.0022uF Coupling - 100K - 250K Pot - 150K OD2 Grid
OD2 Cathode 1uF/1.8K
OD2 Plate 120K Dale MF
No snubbers
Overdrive tone stack 500pF/0.022uF/0.022uF
PI Coupling cap 0.01uF
NFB 4.7K to 4 ohm tap, 2Kpot 390/1uF
The rest of the circuit is as per the schematic
All caps are OD PS Series and Sprague 1KV Ceramics
All plate resistors Dale RN65.
Any advice or pointers would be welcomed. I'm considering rebuilding the PS to use the series 47uFs and parallel resistors. Any thoughts ?
Thanks a ton guys !
