If the cord gets tripped over or pulled on, it simple breaks free from the amp.
Usually with no damage.
Just ask yourself though, how many professional builders actually know anything about UL, CE or any other certification? HAD, I believe, was aware of this because he included the note that this wasn't a production product but an experimental prototype in his 'contract'. That line doesn't seem to serve anything contractual other than to attempt to limit his liability.dehughes wrote:Interesting....then many professional amp builders would be in the wrong. I don't really see how it would be a bad thing...feel free to elucidate....
Yes, Mark, my British ex-patriot friend who is an engineer refers to things like the green wire as "redundant" and I always get a laugh at his use of the vernacular. I was aware that the green and white go to the same buss bar in the service panel box. I'm not sure that everyone realizes this. I've done a bit of electrical work and was actually surprised the first time I saw this.M Fowler wrote:All is good Phil.
As for people worrying about shocks if a wire came off, this is why you use a fuse. All should know that the black power wire is hot, the white wire is neurtal and the green we call ground. The fact is white is grounded at the grid in all USA electrical power household distributions. The extra added green wire came about as an extra precaution to provide and extra means of grounding the recepticle boxes and lighting boxes. If you opened a 200 amp service panel the white (neutral) and bare wires of your 14/2 romex wire goes to the same buss bar. The black (hot) goes to the breaker.
Building guitar amps has a theory and application all of its own and my electrician brother does understand one thing I am doing inside that little tiny box I call an amp.Mark
I don't know if it is a USA electrical code or just locally by state but, electrical main boxes on residences as well as commercial main wiring have required a separate buss for grounding which actually has a heavy gauge copper wire that goes outside to a deep ground stake for years.Phil_S wrote:Yes, Mark, my British ex-patriot friend who is an engineer refers to things like the green wire as "redundant" and I always get a laugh at his use of the vernacular. I was aware that the green and white go to the same buss bar in the service panel box. I'm not sure that everyone realizes this. I've done a bit of electrical work and was actually surprised the first time I saw this.M Fowler wrote:All is good Phil.
As for people worrying about shocks if a wire came off, this is why you use a fuse. All should know that the black power wire is hot, the white wire is neutral and the green we call ground. The fact is white is grounded at the grid in all USA electrical power household distributions. The extra added green wire came about as an extra precaution to provide and extra means of grounding the receptacle boxes and lighting boxes. If you opened a 200 amp service panel the white (neutral) and bare wires of your 14/2 romex wire goes to the same buss bar. The black (hot) goes to the breaker.
