Confused about Filter Cap Bleeder Resitor and Grounding
Hey guys, I am using Ron's Rocket layout and cannot see exactly which way I should wire these filter caps and bleeder resistors to ground. I have attached the schematic the way I think Ron's layout say to do it.
It is difficult to see exactly where the wires go but I think I figured it out...why not combine C16, C17 and C18?
									Greg
						Re: Confused about Filter Cap Bleeder Resitor and Grounding
From looking at Ron's layout, he does have the grounds of the 20uf caps connected together then to ground.
He is using a ground tab on the rect socket.
B+3, B+4 and B+5 come off the + ends of the 20uf caps.
Would this make more sense? Why not?
Are most of you guys grounding filter caps at the forward side of the chassis...up where the choke is?
Please post a picture or two if you have a good way to do this?
Also why do some Rockets have the grounding bar soldered to the pots continue to a grounding lug near the chock and some do not?
									Greg
						I am using an older schematic
Ok so I rechecked the schematic and it is a different version than the one i am using...UGH. The latest and greatest does not include the bleeders. Is it fair to say that if you understand the danger and how to avoid stored current and use the appropriate method to drain the caps that the bleeders are not necessary?
Gary, thought it would be a good idea for me...total newbie...to use the bleeders. I have to say that as long as it does not adversely affect the DONNA ROCKETS tone I think it is excellent advice.
So I plan to use the bleeders...anyone have a good picture? PLEASE!!!
Greg
Hey Greg, I posted some pictures of my recent rocket build that shows my filter cap grounding.  I connected the 20uf caps together and ran the ground wire next the rectifier.  Did the same with the 40uf caps.  Should be able to see it the pictures.
https://tubeamparchive.com/viewtopic.php?t=7978
Greg,
Here is my "Rocket" build with bleeders. Ground lug to B+ pin on Rect.
https://tubeamparchive.com/viewtopic.ph ... ght=#68834
Express build.
https://tubeamparchive.com/viewtopic.ph ... sc&start=0
Gary
Express build.
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
The bleeder resistors seen on a lot of amps are actually balancing resistors that equalize the voltage to the filter caps.
The side benefit is that they bleed the voltage off when powered down.
				Paultergeist
I dug up this very old thread -- using the search function -- because I am looking for information regarding this point. I had assumed -- until I read Structo's post -- that the bleeder resistors on the power supply were only to discharge the filter caps. I have never heard of the "balancing resistor" functions before.Structo wrote:The bleeder resistors seen on a lot of amps are actually balancing resistors that equalize the voltage to the filter caps.
Can someone explain the logic of the balancing resistors to me?
You need them if you have filter capacitors in series - usually to increase the voltage rating. They ensure the voltage is equally split over both capacitors. If you didn't have the balancing resistors, most of the voltage would be across the capacitor with the lowest leakage current.Paultergeist wrote:Can someone explain the logic of the balancing resistors to me?
Look at R82, R83, R88 & R89 in the power supply of this (click it & zoom in!):
[img
				Paultergeist
Tillydog,
That is a perfect explanation; and I think that I understand the issue now after looking at the schematic which you were so kind to link to your reply. Thank you very much for the explanation and assistance.
Paul
Paul
				vibratoking
Just to avoid a possible confusion.  You can approximate the circuit by viewing the caps as open circuits.  This result is that the resistors form a voltage divider.  If the resistors are equal then the drop across each is equal.  You could have resistors of different values which would then provide a different drop across each.
