What would you build...
DonP
Post by DonP »
If you had a 320-0-320 tranny that can deliver 85ma?
Taps for 5v 3a and 6.3v 3.2a.
I'm not sure if the HT current is enough to support a pair of 6V6 or EL84s.
Thanks.
Alexo
Re: What would you build...
Post by Alexo »
You can use a choke-cap configuration coming off the rectifier and probably get your voltages down around 300 volts for a single ended 6V6/EL84/6AQ5 build. I've never run a guitar amp with a choke in the psu before the first filter cap, but 85ma is really only enough for a single-ended amp, and without the choke, your voltages will be too high (450-ish) for a good SE amp imo, while the LC filter's noise rejection will be beneficial to an SE amp..
Alexo
Post by Alexo »
Forget everything I just said. Use a 5Y3 and build SE 6V6.
DonP
Post by DonP »
I was thinking the 5Y3 would drop some of that voltage. I have some 3H chokes as well.
No chance of a push pull pair, huh?
mark enger
Post by mark enger »
i dont think it will do it for a pp. how bout a kendrick roughneck 6l6 maybe a octal preamp tube could be interesting. or build a marshall inspired valve jr i think you could use a couple of 12ax7 with that pt. check over at sewatt they got some cool se stuff great guys to
skyboltone
Post by skyboltone »
You can try a 6K6 or 6K6G. They are not hard to find. Brandon (bludotone) has had some success with this tube.
http://frank.pocnet.net/sheets/127/6/6K6GT.pdf
dave g
Post by dave g »
I would build one of these:
DonP
Post by DonP »
mark enger wrote:i dont think it will do it for a pp. how bout a kendrick roughneck 6l6 maybe a octal preamp tube could be interesting. or build a marshall inspired valve jr i think you could use a couple of 12ax7 with that pt. check over at sewatt they got some cool se stuff great guys to
Yep, for the preamp, I'm pretty much hooked on the 2203. I have a 2.5 watt version using a 50C5 and a 35W4 rectifier.
DonP
Post by DonP »
dave g wrote:I would build one of these:
A KT88 might be hard to pull off.
Allen is just down the road from me (well, maybe 40+ miles).
Has anyone tried one of these? It's very similar to my 2.5 watt build, except that I went with the cathode follower before the tone stack. I like the feedback - I'd be tempted to wire in a presence control.
dave g
Post by dave g »
You wouldn't want to use a KT88 with only 85mA to play with (an EL34 would be cutting it really close, too), but I think a 6L6 would be rockin' :D
