Will taking the signal from the input and feeding it to 3 different input tubes in a multichannel design unnecessarily load the signal? If the signal is getting loaded, is there a way to buffer it internally before it gets to the gain stages?
The input will go like this:
INPUT---through 68k resistor to grid of 12AX7 Clean Channel
Jumper from the grid of the 12AX7 to grid of EF86 Clean Channel.
INPUT---through 68k resistor to grid of 12AX7 Dirty Channel
Input to 3 Gain Stages
Andy Le Blanc
Re: Input to 3 Gain Stages
just watch out for the total impedance that is seen by the instrument and the
tube. You could go as far as to use a RC circuit for each grid to control what
each "see's" and to pre-shape tone, to provide a measure of isolation for each, but there will be an insertion loss.
lazymaryamps
Another idea might be to voltage divide the output of the clean AX7 and use that to drive the dirty AX7 - they'd be out of phase, but without knowing the rest of your design I don't know if that would be a problem. The pentode shouldn't be much of a load. I've never tried it, but I would think you would be able to piggyback the EF86 to either triode grid without penalty. Others with more experience with EF86s might disagree...
W
W
