Hi everyone, I am new here and to building tube projects.  I have done the stompbox and guitar building thing, so amps is the next logical step.  That said, I wanted to start with something not quite so "scary" in terms of electricity (the wife is 7 months pregnant and wants the baby to have a living father).
So what I am thinking is doing a submini amp with 6111's and 5902's (similar to Dana's lil devil), but I have several different things I want to do with it.  My main question is regarding the power supply.  I know I need 6.3V to the heaters, but I would like to run the tubes at about 100V.  I was hoping I could get a single 115 primary/6.3 secondary transformer and run the tubes using just rectified mains voltage.  But then I ran some quick numbers and after rectification, my 115V turns into about 160V which is about the max my tubes can handle and I would like to be safe and run them a little lower.  My question is if there is a way to drop either my mains AC or my rectified voltage to an acceptable level without a transformer.  I also considered using a charge pump on a rectified portion of my 6.3V, but the charge pumps I have looked at can't supply enough current for all the tubes.  Any ideas?  If there is a thread regarding this, I would be thrilled to read it, I just didn't find anything in all my searches regarding this topic.  Thanks.
									Some newbie questions regarding submini's
Exact science is not an exact science
						Re: Some newbie questions regarding submini's
Hi,
I am planning something similar, and I think you can run the transformer backwards, from a 6v supply, to get the B+. The 6v supply powers the heaters. Here is a link: http://www.jjs.at/electronic/class_ab_subminiature.html
Look at the power supply section. If you want a lower B+, then use a transformer with a higher voltage secondary (which you will be using as the primary), e.g. if you put 6v into a 115v-9v transformer, you will get approximately 75v before rectification, and 105v after.
Hope this helps, and good luck!
Daniel
Daniel
Two back to back transformers works well as described above, as long as the current demand isn't excessive - should work fine for sub-minis.
In the interest of ensuring that your offspring grow up in a two-parent family, do not under any circumstances use directly rectified wall voltage to obtain your HT!!!
W
W
Thanks for the responses.  After doing some more poking around, I think I can get away with a single 115/6.3 transformer and use a nixie power supply for the high voltage.  If you aren't familiar with it, it basically uses a 555 timer, bc547 and an inductor and some caps to take a reasonable input voltage (9V ish) and converts it up to anywhere between 100V and 200V depending on a trimpot.  I think this should work well.  If not, then the two and half bucks for the parts won't kill me.
