bjm007 wrote:I've tried the RW&B's but found them to be VERY dark compared to the tone I'm striving for.  Does anyone else fell the same????????
Any thoughts???
As far as the RW&B's I tested one a while back and when I first installed it in the amp it sounded murky.  But after several hours it opened up a lot and sounded really nice.
I also installed a RW&B into a 20 watt amp that I had built for a local player.   He has been extremely happy with that speaker and his tone is anything but dark.   He had tried the Wizard (too much cone cry) and the Tonker (some cone cry) before we settled on the RW&B.
Can't comment on the scumbacks or G12-65's as I have never used them.   As far as other Emi's I have tried.
Wizard - This is a pretty nice speaker,  if you use them in a 4x12 combination.   This distributes the load across all speakers and as such they work really well.   In a 1x12 or 2x12 they are almost unusable due to cone cry that appears all over the neck.
Tonker - I currently have one of these in a combo and a 1x12 cabinet.   These are note bad speakers but they also exhibit cone cry on the 17th and 21st frets of the high "E" string.  It is very subtle,  but it is there.   As far as tone,  at first I really like them,  but the more I have played them I hear type of "nasal" quality that I am really starting to dislike.
Not an Emi,  but was the speaker of choice from Dr. D,   the EV 12L.   This is a great speaker for this type of amp (if you like them).   There are a tad sterile (they do not color the sound to my ears) but give a great overall sound.    This is what will go back into my combo next time I have the amp open.
Other speakers that I am going to test over time are the Tonespotters,  Texas Heat and the Celestion Classis Lead 80.    I am also still looking for the perfect speaker that doesn't break your back when you lift the amp.
Gary
