T-Rex MV question
bcmatt
T-Rex MV question
Post by bcmatt »
I know maybe it is a sin to suggest a MV for something that is somewhat Trainwreck related, but here's the scoop:
I'm putting together a T-Rex for my brother-in-law as a Christmas gift and it will be his very first tube amp. Cheers Richie; I believe this is your design, and it seems like it is exactly the sort of thing that he would like.
I'm still waiting for my turretboard material to come in from Turretboards.com before I officially begin.
I am using the chassis and faceplate for a Ceriatone 18 watt TMB combo.
I plan to use Dana's VVR as well on this project and I think it will be great. (will use a 3 position DPDT for standby/power to free up a hole for the VVR)
(So, I guess this amp will be a real tribute to the Hall brothers)
There is also a place on the Faceplate that is meant to be a MV for the TMB channel. I like this idea because my brother in law seemed to be into the preamp type distortion from my JCM and I am hoping that I can give him that option on this amp as well (even if he outgrows it and ends up keeping it cranked anyways-opting for the VVR option more). Then this could also give him the option of balancing clean and dirty volumes and use an A/B pedal for more versatility if he chose.
So, what do you think trying the MV in this amp? Does adding another pot suck a bit of power out of the circuit or throw off the finely tuned balance or anything? Has anyone tried that on T-Rex?
I was just thinking of throwing a 1M pot between pin #1 of V2 and the 100n cap before the phase inverter (and wired to ground). Does doing this mess with anything else? When the pot is fully cranked does it really seem like it's not even there? Or, do I need to change that 220K resister beside the 100n cap? I'm not afraid to try and play with it a bit, but I sure would love some tips. If a cranked MV pot really didn't mess with the balance of the circuitry than you think everyone would just pop one in their trainwreck clones...but they don't seem to.
CaseyJones
Re: T-Rex MV question
Post by CaseyJones »
The T-Rex is a Mark Huss creation.
With VVR the master volume is redundant but...
It's a different tone from the VVR. It's good to have all your options available.
bcmatt
Post by bcmatt »
CaseyJones wrote:The T-Rex is a Mark Huss creation.
Oh, I thought Richie designed it and Mark Huss drew it up and posted it.
Ya, I know it is rather redundant, but I think he might appreciate the option of that kind of tone as well. If it was for me, I'd probably choose the VVR alone, but versatility is key in this case.
Jana
Post by Jana »
If I am thinking of the spot you are talking about, you will have to put another coupling cap in there. neither the plate of the preamp tube, nor the grid of the phase inverter should have a DC path to ground through the master volume.
edited late night typo
Richie
Post by Richie »
I guess you have to blow up the schem and read the fine print :)
unless your talking about these amps which also now have an amp named T-rex. http://redironamps.com/
There are also amps or pedals made i think in the UK named T-rex..
Some people like the post MV, if you use the VVR.. so for this amp,i'd try that to have something that would maybe have a different function for the amp.
The circuit is open for experiments. You can tweak some spots for more or less gain, maybe change the voltage divider,or cathode resistor.bypass cap. I'm sure there are many things you could do. Seems no one amp is for everyone, or no,one tweak or mod on any amp is for everyone.
bcmatt
Post by bcmatt »
Is it a pretty hard and fast rule to keep B+ voltage wires away from tone stacks and tone controls?
I am considering the idea of just trying the VVR as the only MV (scaling the whole amp of course)
Then I would be feeling that I must put the pot for it way over with the T-Rex input where the faceplate is marked for MV. I could potentially put the VVR components on the Eyelet board right in the middle there too, but something tells me this could be a real big no-no and the cause of the worst hum ever. What do you think?
I would only like to drill my Turretboard material once, once I am confident about a layout.
