Hi guys;
Over the years I have used sturdy stompswitches for their reliability -- like carlings, fulltones, etc. I'd like to know if anyone has a recommendation for a long-life switch that doesn't make so much mechanical noise. It could also be a DIY project from available parts. I do like the TS style mini pedal but haven't ever reverse engineered one.
Thanks, Skip
Mechanically quieter footswitch?
- Luthierwnc
Re: Mechanically quieter footswitch?
Carling also makes momentaries that are rugged and quiet. You would need some minor flip-flop type logic to manage the relays.Luthierwnc wrote:Over the years I have used sturdy stompswitches for their reliability -- like carlings, fulltones, etc. I'd like to know if anyone has a recommendation for a long-life switch that doesn't make so much mechanical noise. It could also be a DIY project from available parts.
PC Mount Carlings are pretty quiet
- phsyconoodler
The box the switch is mounted in contributes a great deal to the noise.A hollow metal box is very noisy.A wooden box with just enough routed for the switch and wires is actually very quiet.
Crystal latice or vacuum,that is the question.
- Luthierwnc
I suppose I could fill it with construction foam
No moving parts in there. sh
- phsyconoodler
- UltraHookedOnPhonix
I've had pretty good success with the Alpha DPDT. Mouser part#: 107-SF12020F-L
Also, the Carling "X-wing" is pretty quiet.
Of course, both these do generate audible "clicks" when actuated but considerably less than the more rugged Carling 316-PP or the blue 3PDT. Reliability wise, I've used both without failures yet (knock on wood!!!)
- Luthierwnc
It is a minor issue but I've always disliked hearing the click before the lead. sh
