124 Layout Revised
talbany
Re: 124 Layout Revised
Post by talbany »
Updated Again!!
T.
Looks like the orange wire to the presence pot got disconnected at both ends.
MPM
talbany
Post by talbany »
Got it
ic-racer
Post by ic-racer »
Here is another, the shell of the bias pot needs a ground wire to V6 pin 8.
ic-racer
Post by ic-racer »
Also, indicate that the 6v transformer primaries connect to the fuse and the 'mains' switch (just like the main PT).
ic-racer
Post by ic-racer »
"Drive" and "Vol" post should be "Level" and "Ratio."
Wiper of the "Level" pot (currently "Drive") is indicated as V2 pin 7, but should just a letter designation as it actually goes to the 180k grid stopper first, before the pin (which would be pin 2).
ic-racer
Post by ic-racer »
There is a jumper wire between the two top poles of the Rock/Jazz switch that should not be there. (ie connecting the paired .01 caps and the 100k resistor).
talbany
Post by talbany »
Now It's Starting to look like a Layout!!
Foot Switch anyone!!!
Tony VVT
ic-racer
Post by ic-racer »
Here are some footswitch pictures.
The first is a presumably Dumble-converted Fender Super Twin switch photographed with an ODS of similar vintage to #124. (Unknown #7, on Rob's picture archive). Clever the way the "EQL" and "DST" label from the original Fender Super Twin matches up with the functions of the ODS.
The second is a my own converted Fender Super Twin two-button pedal like what may have originally been with #124.
The third is one posted by Gil that presumably would follow closely (exactly?) the way Mr. D did it.
ic-racer
Post by ic-racer »
duplicate
argonaut
Post by argonaut »
You guys are awesome to take the time to do this.
The layout looks great.
Thank you!
UltraHookedOnPhonix
Post by UltraHookedOnPhonix »
Gil helped me with the footswitch a while back and here's the layout:
[IMG:931:1024]http://i205.photobucket.com/albums/bb17 ... 24FTSW.jpg[/img]
talbany
Post by talbany »
Thanks everyone for the help!!!!
I've been real busy here lately and will finish it up as soon as I can..
I was thinking it would be really cool if we could have a Dumbleator to match...I see angelodp.. has done a fairly nice layout...as well as Brandon's tutoral and think I have enough info to get started...It would be great to have someone here who has been in a few to moderate the layout and make sure everything stays authentic.. Any takers
Tony VVT Amps
