Bias circuit filtering
Funkalicousgroove
Post by Funkalicousgroove »
Do you guys think it would make a big difference if I used a 47uf cap instead of a 10 uf cap in the first stage of the pi filter in the bias circuit on my express?
LeftyStrat
Re: Bias circuit filtering
Post by LeftyStrat »
It should be okay. Bias supply is not as critical as other areas. Besides, you'll providing more filtering. Just make sure the voltage rating is high enough.
