Real or memorex??
Funkalicousgroove
Real or memorex??
Post by Funkalicousgroove »
Here is a fun one :D
UltraHookedOnPhonix
Re: Real or memorex??
Post by UltraHookedOnPhonix »
Did you make that? If so wow!
It doesn't look like the formica & PS boards are doubled up so I'm going with Memorex he he!!
jelle
Post by jelle »
Nice belly...errr.... amp, Brandon! :lol:
dogears
Post by dogears »
Is that Rob's amp??
Robert
Post by Robert »
The lead dress and details give it away. To tidy for HAD. And I used to think he was more obsessive than you. :lol: :lol:
Hey do you mind telling us if the goop improves the tone and if so what brand do you use. I read on TGP ... :wink:
ampdork
Post by ampdork »
No relay supply so it must be memorex.
Nice work.
ampdork
Post by ampdork »
Not even close to memorex but if having pictures posted is helpful here is another.
Caveats are. Small perf board with trimpot. V2 cathode and resistor spots are reversed. The thinking was it would be easier to tweak cathode R values and indeed it was....too bad I still had to get under the HRM board to change plates....LOL!
Carbon films where everyone says should be metal films. Metal films where others say carbon should be.
PCB will eventually be used for all the auxiliary circuits but this one is all eyelets....even the stupid fet....LOL I dislike flying leads the way D did it so grid R's for power tubes are also on terminal strips.
Lots of other tid bits that the astute could point out but I am aware of all of them as well...
All cabinetry and face plates done by me as well...
HIH
benoit
Post by benoit »
For me the suspicious thing was the hole for the OT secondaries. But that's only based on gut shots of 3 or 4 amps so who knows.
jelle
Post by jelle »
How 'bout TAD 220uF filter caps and a Heyboer PT? Besides the impeccable leaddress, of course.
ic-racer
Post by ic-racer »
Either way it's great. If it is the real deal, thats good, I have not seen that one yet.
If it is a clone, now your talking! That it excellent!!
In addition to the other stuff pointed out, the tube sockets look like the ones in a Ceriatone, and the FET jack is not an enclosed jack so I'm going to say Memorex.
Funkalicousgroove
Robert wrote:The lead dress and details give it away. To tidy for HAD. And I used to think he was more obsessive than you. :lol: :lol:
It's blue elf puke, and yes it makes all the difference :D
Deric
Post by Deric »
I'm an idiot but, my guess is it looks too purty to be the real deal...
Whoever did build it, nice!! 8)
Deric®
Guitarman18
Post by Guitarman18 »
Is that European or North African elf, Funk? I find there is a difference in tone, admittedly a subtle one but still a difference.
Awesome, Funk. Is that powder coat on the inside or paint of some sort?
tonelab2
Post by tonelab2 »
Not enough solder sputter to be the real deal.
Great looking amps, high class work.
Funkalicousgroove
The chassis is black annodized, it was a real PITA to sit and dremel all the ground points, but it looks cool when it's done.
The Sockets are Belton Micalex, the best current production IMHO, quality is fantastic.
If you guessed memorex you are right, I built this one at the beginning of this year for a fine fellow who is putting it to good use :D
