1uf on presence
andrew
1uf on presence
Post by andrew »
Hello all, I'm out of 1uf film caps so can I use a 1uf electrolytic cap on the presence control? Thanks!
talbany
Re: 1uf on presence
Post by talbany »
Absolutely!! I prefer them Just get the polarity right or they will scratch on you.. My Faves are the Mallory 150"S Then a good Sprague Electo...
Tony VVT
skyboltone
Re: 1uf on presence
Post by skyboltone »
andrew wrote:Hello all, I'm out of 1uf film caps so can I use a 1uf electrolytic cap on the presence control? Thanks!
Won't hurt a think if that's what you mean. When you place your order, try a Tantalum 1uf too.
glasman
Re: 1uf on presence
Post by glasman »
The real deals used most often eletrolytics and less often tant's for the 1u0 presence controls.
The 0u1 PI used a small poly film cap.
About 5 miles south of I-94
www.glaswerks.com
talbany
Re: 1uf on presence
Post by talbany »
For A smoother flavor Oil filled are kind of cool there.. This is the only place I would use an oil filled cap...Built one with all Angela Oils Sucked!!!
bluesfendermanblues
Re: 1uf on presence
Post by bluesfendermanblues »
FWIW #124 uses a small tantal - check the picture(s):
http://personalpages.manchester.ac.uk/s ... 124067.jpg
and the whole show here:
http://personalpages.manchester.ac.uk/s ... 20%230124/
I belive HADumble is known for using surplus parts, so I guess you should use your ears and the tips on these pages (which is a circular statement)[/img]
Re: 1uf on presence
FWIW, I use a 1uf Tant.
