I had it on clean and had the volume and master cranked.
When I dug into a string, the attack was almost muted and the note swelled dramatically..
Sounded like crap basically.
I have 110K/ 120K plate resistors on the PI.
I am running it into a 2x12 with Tonkerlites.
Is this normal or is something going on.
I have 220K/150K Rp on both V1 and V2.
Rk on both is 3K3 and 2K2
With 4.7 uf, 10 uf, 4.7 uf, 4.7 uf on V1 and V2 respectively.
Could this be simply speaker compression or the amp?
I don't notice the compression so much when in OD.
Would changing the plate resistors on the PI to 100K/ 100K have any effect on this?
Or could it be the filter caps simply being overwhelmed?
Thanks for any thoughts or comments on this.
Of course I don't operate this amp at those setting normally.
Kind of like driving a car, I wanted to see what it would do wide open.
Oh and the bias is set at about 32ma.
