'nuther compact *umbleator
brownnote
Post by brownnote »
Remember kids...Always adjust for minimum smoke!
D'Lite Kits: http://store.bnamp.com/dlitekits.html
mcinku
Re: 'nuther compact *umbleator
Post by mcinku »
I just seen this on D'Lite forum... so your plan is to offer this as a kit, great news.
One question, what about a PT for us Europeans.
:wink:
nickt
Post by nickt »
Hey brownote - where do you get those knobs? I found a site "sometime" but have completely forgotten it (as usual) :roll:
Nice little mumbleator btw... 8)
sergio
Post by sergio »
Nickt , look here for the knob:
http://www.banzaieffects.com/Black-poin ... 17429.html
Sergio
heisthl
Post by heisthl »
www.RedPlateAmps.com
stelligan
Post by stelligan »
brownnote,
Nice build and size. Been looking for a box to fit in the bottom of a combo where the reverb pan used to be. With controls and jacks on top, that might work for me. Where did you source the box?
Funkalicousgroove
Post by Funkalicousgroove »
Nice and teeny, how do it sound?
brownnote
Post by brownnote »
nickt wrote:Hey brownote - where do you get those knobs? I found a site "sometime" but have completely forgotten it (as usual) :roll:
I get the knobs at smallbear too...thanks :)
stelligan wrote:brownnote,
I was going to lay it out exactly that way too...this box is an off-the-shelf steel box by Hammond IIRC, and it doesn't work well for the back of the combo thing because the speaker magnet just grabs it!
Funkalicousgroove wrote:Nice and teeny, how do it sound?
thanks this one is twice the size of the last one, which was point-to-point...it sounds great, but I'm building another one HAD style (as close to original as possible) as a baseline for comparison.
odourboy
Post by odourboy »
When you dial in your Dumbleator settings, how much attenuation is appropriate from input to send? Looking at Scott's 'Bludotone In The House' photo, it looks like the Dumbleator is set so the signal is attentuated by a factor or 10 - so 10V in = 1V out. Does that sound about right?
johan
Post by johan »
IIs it possible to get a DLator to fit in the bottom of a DLite head or is that impossible?
brownnote
Post by brownnote »
odourboy wrote:When you dial in your Dumbleator settings, how much attenuation is appropriate from input to send? Looking at Scott's 'Bludotone In The House' photo, it looks like the Dumbleator is set so the signal is attentuated by a factor or 10 - so 10V in = 1V out. Does that sound about right?
I think it varies with the application.
It looks like 1:1 for the outboard gear I'm using...unity on both sides with the send and return at about 12:00-1:00 does the trick without clipping the input.
johan wrote:IIs it possible to get a DLator to fit in the bottom of a DLite head or is that impossible?
Definitely possible, that's actually the design goal.
