Dumble 102 ODS testing
Re: Dumble 102 ODS testing
For a start, dial it down to the most negative voltage on pin 5's, and you will need a way to measure the current flowing through the output tubes.
desertmouth90
Post by desertmouth90 »
martin manning wrote: Fri Jun 13, 2025 4:43 pm -17V is much too high (not negative enough). You will need around -50V there.
Edit: above you had -50V available for biasing. Have you just not set the bias yet?
Bloody trim pot, I manhandled it abit and now I got -52v
Weird
desertmouth90
martin manning wrote: Fri Jun 13, 2025 5:14 pm For a start, dial it down to the most negative voltage on pin 5's, and you will need a way to measure the current flowing through the output tubes.
I was thinking of buying a bias meter, but I have a multimeter. Each Half winding has a resistance of 18ohm
ok, you can use that. Did you have a look at the document here: https://ampgarage.com/forum/viewtopic.p ... 60#p474160 ? You will be measuring current as shown at C in the diagram.
desertmouth90
martin manning wrote: Fri Jun 13, 2025 5:51 pm ok, you can use that. Did you have a look at the document here: https://ampgarage.com/forum/viewtopic.p ... 60#p474160 ? You will be measuring current as shown at C in the diagram.
Got an A in maths at school, that was the last time I used it. Will go through this with my sister (she’s an electrical engineer)
Well alright, great resource there! She should be able make sense of it, but I’m betting she hasn’t worked with valves before ;^)
desertmouth90
martin manning wrote: Sat Jun 14, 2025 12:54 pm Well alright, great resource there! She should be able make sense of it, but I’m betting she hasn’t worked with valves before ;^)
No she has not, big gas turbines yes!
I will be able to work it out eventually.
It appears somewhere in the circuit the signal is getting pushed to ground.
Also appears that SPK2 Output is the main output for some reason… who only knows!?
timrobertson100
Post by timrobertson100 »
desertmouth90 wrote: Sun Jun 15, 2025 9:48 am It appears somewhere in the circuit the signal is getting pushed to ground.
Can you please post new pics, including a closeup of your output socket wiring?
desertmouth90
timrobertson100 wrote: Sun Jun 15, 2025 6:30 pm
As requested, two 22uf filter caps were out of the damn circuit… a rookie error from… er… a rookie!
FX loop and outputs changed to 12a from 12b. Will speak to mouser about this before my next order.
If you need anymore closeups of certain locations I can provide. Also tonight I will install 1R resistors to the Cathodes for biasing as apparently I forgot how to do maths.
Cheers
Clive
desertmouth90
Dont understand it, all voltages are perfect. 455v Screen Voltage - 457v Plate Voltage.
make it make sense haha
OT is wired up correctly - I checked with the manufacturer
Richard1001
Post by Richard1001 »
I looked at your pictures and wonder what output transformer you use?
On most output transformers the primary winding would be red, blue, brown, with red being the centre tap. On your amp there is a red wire that goes to the anodes on one side and brown going to the anodes of the other tube pair. And then on the secondary side it looks like there is another brown wire going to ground (soldered on the speaker ground) It would be odd to have the same color brown wire both on the primary and secondary side of the transformer. I can't see which color wire is going to the B+
Maybe it would be worth checking the wiring.
desertmouth90
The Output transformer was custom wound by Michael at Modulus Amplification.
Hes also done my 100 power transformer and 50w transformers (OT and PT).
And on this OT he used Marshall wiring as follows:
https://modulusamplification.com/100w-o ... 3202-p.asp
although this is a custom 2k OT for 4 6L6s
Also just cut my foot on a Vintage fender pt (how very apt!) dont leave them on the floor where you are working again!
desertmouth90
I HAVE FINALLY DONE IT!
It’s unbiased but I have output!
I will get it biased. And the overdrive and internal pots need biasing.
The problem is the input is also 12b not 12a! I dunno whether to cry or be furious!!!!
How do I upload videos?
Thank you all that helped!!!! 🥲
desertmouth90 wrote: Sat Jun 21, 2025 4:20 pm I HAVE FINALLY DONE IT!
Great! Get the bias set properly, and dial in the internal OD entrance and PI trimmers. Those are not bias, they set the base OD level and the PI/Output stage balance. There is a lot of discussion on how to go about that on the forum.
timrobertson100
Congratulations!
