2025 Monkeymatic Palisade 30w (Liverpool, non traditional)
Re: 2025 Monkeymatic Palisade 30w (Liverpool, non traditional)
Excellent! Looks great. I don't see any provision to vent the heat. Do you see this as unnecessary?
Guy77
Post by Guy77 »
Looks absolutely beautiful !
I love having an LND 150 input stage in front of my amps!
Your method is a very cool way to build it. ( I usually buy it already assembled on a Cliff jack )
Is there way you can roll off the gain on your LND 150 with a Trimmer pot?
Thanks for posting!
Cheers
Guy
Guy77 wrote: Sat May 24, 2025 1:16 pm Looks absolutely beautiful !
Thanks for posting!
Cheers
Guy
No, I didn't install a trimmer. Where do you get the Cliff/FET input jack thing?
Guy77
Post by Guy77 »
xtian wrote: Sat May 24, 2025 3:34 pm
Thanks for posting!
Cheers
Guy
This is LND 150 gain stage on a Cliff jack that I like to use. It can add a lot of gain by adjusting the trimmer. I order it with a 25k trimmer and its more than enough.
I am the one that placed the review.
https://grangeramp.com/product/superfet-jack-3/
Cheers
Guy
maxkracht
Post by maxkracht »
Amp and cabinet look great! nicely done!
i'm too cheap to spend $50 on a premade board, but seemed like a fun idea. Here's an untested version with some added features. Mostly SMD, but allows for a through hole lnd150. Will report back if it works/what dumb layout mistakes I made. https://oshpark.com/shared_projects/GvzLdhnL
Edit: further info https://ampgarage.com/forum/viewtopic.p ... 84#p476284
TUBEDUDE
Post by TUBEDUDE »
Very nice clean build, as usual with your builds! Yeah, not every great sounding build is also bedroom friendly.
How's the baseline hum? I've never worked on a Liverpool, does the original have the O.T. and power xfmr on top of each other? It looks like Ken had real estate to spare. Just curious.
TUBEDUDE wrote: Mon May 26, 2025 10:39 am Very nice clean build, as usual with your builds! Yeah, not every great sounding build is also bedroom friendly.
It's very quiet, even with the master volume wide open, but only rates an A- in my book. There is a little radiated hum from PT to OT, which I was able to mitigate about 50% by adding an aluminum shield between the two. What's curious is that I can just float that shield in place by hand, without it touching the chassis (meaning the shield is not electrically connected to the chassis) for it to work. Then, screwing the shield to the chassis makes no change. Just its presence in space is enough to deflect the field away from the OT. All this was figured out using the headphone trick.
TUBEDUDE
Post by TUBEDUDE »
xtian wrote: Mon May 26, 2025 3:32 pm
I'm a big fan of the headphone technique. I start every build using it to place the iron. The circuitry develops from there.
An A- is a good score. That is odd the way the field is diverted without connection, especially with aluminum. Good work!
xtian wrote: Mon May 26, 2025 3:32 pm What's curious is that I can just float that shield in place by hand, without it touching the chassis (meaning the shield is not electrically connected to the chassis) for it to work. Then, screwing the shield to the chassis makes no change. Just its presence in space is enough to deflect the field away from the OT.
I'm going with the magnetic field from the PT is inducing eddy currents in the aluminum sheet, dissipating its energy before it can get to the OT.
I noticed the same deal when positioning a choke between PT and OT. Bends the field.
didit
Post by didit »
Hello --
Try mu-metal.
LOUDthud
Post by LOUDthud »
Question: How does the LND150 front end sound with Overdrive pedals ? I've always been under the impression that a 12AX7's grid current played a significant role.
I've been playing this amp at home with a variety of overdrive, distortion, and fuzz pedals. Sounds great. But even with pedals engaged, I'm not pushing a signal that's any larger than usual into the amp. Nowhere close to overdriving the LND150.
12A?7s are linear when they're not being driven into distortion. You can't easily drive the first gain stage into distortion with an electric guitar. The LND150 sounds exactly the same to me as using a valve as a first gain stage.
LOUDthud
Post by LOUDthud »
xtian wrote: Mon May 26, 2025 9:52 pm 12A?7s are linear when they're not being driven into distortion. You can't easily drive the first gain stage into distortion with an electric guitar. The LND150 sounds exactly the same to me as using a valve as a first gain stage.
That's true, but the point of my question is how the LND150 behaves with an overdrive pedal. An overdrive pedal can easily drive a 12AX7 beyond it's linear range. Look at the X-Y oscilloscope pics in post #3 of this thread:
https://www.ssguitar.com/index.php?topic=3732.0
You probably have to join the forum to see the pics.
TUBEDUDE
Post by TUBEDUDE »
didit wrote: Mon May 26, 2025 7:49 pm Hello --
Try mu-metal.
It works well, but is expensive, and if cut or bent it requires annealing to keep it's effectiveness. I would think steel would work better than aluminum. At any rate he solved it, and cheaply.
