Bastardized 1962 Blonde Bandmaster
Fender Amp Discussion
aermotor
Re: Bastardized 1962 Blonde Bandmaster
Post by aermotor »
Reporting back after some discovery. Got the filter caps changed out, new 3 wire power cord and some other misc done.
Fired it up and she works out of the box, here's what I found.
The 'Vibrato Pedal' foot switch on the back has been modified to indeed enable a new OD 'distortion' circuit as Reeltarded and dcribbs1412 said —absolutely wild. The added relay in place of the tube is what's switching the distortion. It appears—though not certain— Normal 1 being the most distortion and Vib 2 being the least, more testing required.
The front 'Presence' knob now acts as a sort of master volume for the whole thing. 'Intensity' is a secondary channel vol for the Vib channel that allows you to turn the main Vib volume all the way up and drive it into the intensity volume for as much distortion for the desired effect.
That's the main discovery, and as weird as it is, it's pretty trick. Old timers modifying their gear to get their own sounds. Vibrato circuit is gone in its place, but that's a worthy sacrifice for now.
After hearing this and understand a bit more it's clear what the intention was, and I can appreciate it. Going to leave it alone for the time being and get some play time in on it.
Secured an early 60s blond 2x12 cabinet I will get outfitted and hooked up to it as well.
Post by Stevem »
It’s very good to hear that you did not just condemn it and take a wrecking ball to it.
Someone who might had passed on put a lot of thought and time into that.
sluckey
Post by sluckey »
aermotor wrote: Fri Nov 08, 2024 10:06 pm The added transformer in place of the tube is what is driving the distortion.
That metal box that replaced V4 (p/o vibrator circuit) is NOT a transformer. It's a RELAY.
aermotor
Post by aermotor »
Stevem wrote: Sat Nov 09, 2024 12:40 pm It’s very good to hear that you did not just condemn it and take a wrecking ball to it.
Haha yea, it was good to at least get it fired up again to understand a bit more what was going on. Ideally I need someone to trace out a schematic on it.
sluckey wrote: Sat Nov 09, 2024 1:17 pm
Yep my bad sorry lol
dorrisant
Post by dorrisant »
Welcome to the forum!!
If you are willing to post a few more pics as the conversation goes, we could help to cipher a schematic from that and what is already posted. Are you comfortable with taking some voltage readings, or resistance measurements? If so, you have plenty of good eyes around here that do that sort of thing for the fun of it. I'm sure others would agree.
aermotor
Post by aermotor »
I would love to do that, just let me know what specific more photos and where to check voltages.
dcribbs1412
Post by dcribbs1412 »
The 180k/3.3M (with small cap) resistors are different from 180k/1M in original Gen2-3 as is the 100k/82k PI
56k NFB resistor?
Any sort of sound clip would also be nice if possible.
dorrisant
Post by dorrisant »
aermotor wrote: Mon Nov 11, 2024 5:57 pm I would love to do that, just let me know what specific more photos and where to check voltages.
Straight(er) shots of the components attached to the pots. Also, some of the ceramic caps and ODs are not clear because the pic is shot from directly above. Maybe skew to the side so we can see the values.
aermotor
Post by aermotor »
Got it on the photos, I'll take some more.
New question, in the power filter cap section, I'm noticing a 27K was removed and replaced with a jumper, and the other values are not factory.
Should be 27K, 27K, 4.7K, 27K but its currently 4.7K, 27K, 6.2K, Jumper — Do I put those back to factory values, or is it like that due to the removal of a tube and other mods that were made?
sluckey
Post by sluckey »
aermotor wrote: Wed Nov 13, 2024 3:17 am Should be 27K, 27K, 4.7K, 27K but its currently 4.7K, 27K, 6.2K, Jumper — Do I put those back to factory values, or is it like that due to the removal of a tube and other mods that were made?
LET IT BE! The jumper is because of the removal of the vibrato circuit. This is no longer a 1962 Blonde Bandmaster. The person that did this extensive mod knew what he was doing.
ampdan
Post by ampdan »
sluckey wrote: Wed Nov 13, 2024 4:06 am This is no longer a 1962 Blonde Bandmaster. The person that did this extensive mod knew what he was doing.
That's indeed a shame. As someone who was buying/selling this stuff in the 70's-80's, when these mods were made, this was already a desirable amp.
Yes he did. It's the implementation of the mods...
aermotor
Post by aermotor »
Yep good call, thanks again. Definitely not a BM anymore haha.
ampdan wrote: Wed Nov 13, 2024 2:26 pm
I truly wish it was factory as well.
Smitty
Post by Smitty »
If you'd rather have factory stock amp one option would be to sell this one an seek another that is closer to what you're looking for. I have to say I'm curious enough about how this amp sounds I may be interested in acquiring it. It's like a puzzle. Please PM me if that's something you'd like to explore.
ampdan
Post by ampdan »
Smitty wrote: Thu Nov 14, 2024 4:22 am If you'd rather have factory stock amp one option would be to sell this one an seek another that is closer to what you're looking for. I have to say I'm curious enough about how this amp sounds I may be interested in acquiring it. It's like a puzzle. Please PM me if that's something you'd like to explore.
The problem with that, is an original would cost way more than you could get for this one as is.
This could certainly be restored to original. I've restored worse than this..It would not be cheap, and would be a labor of love to do it right.
aermotor
Post by aermotor »
Yea, trying to get a factory BM head is going to easily be $1250-$2500 so not feasible. This was my father in laws, who I wasnt really close with, by wife has some attachment to it. Feels wrong to just sell it. Going to just enjoy it for what it is. I will need to get a recording setup in place to get some audio samples.
