I'm having two issues, a lot of noise/interference particularly on the clean channel and a static sound that comes though when playing.
I understand that moving the grid stoppers from the input jacks closer to the tube sockets may help with the radio noise and interference. Any other tips would be appreciated. I've already tried improving the ground scheme and shielding the wires from the input to the tubes.
The static/buzz is a mystery. It's particularly noticeable on the decay of chords/notes. Its really hard to capture on mic but its apparent in the room. Happens with all my guitars/cables/cabs. I thought it was happening on both channels but I can't really hear it on the clean channel right now. Once I have a chance to crank the amp I'll try to recreate it at higher volumes.
Any thoughts on what it could be? Here are a few clips. The first one is from a while back before the mods to the preamp and the noise is a lot more noticeable. The second is from tonight, I'm running a compressor so you can hear the interference from the clean channel clearly and you can still hear the buzz and bit on the gain channel.
https://on.soundcloud.com/K83aD2H8nAkjQe6UA
https://on.soundcloud.com/ktpXezAAySaNeeCq8
Edit: here are better gut shots
So the buzz sounds like a tube rattle or buzz that blooms as the chords fade out.
