Finished Dumblelator
UltraHookedOnPhonix
Post by UltraHookedOnPhonix »
Hello fellow Dumbleers!
I just completed a Dlator and I thought I’d share some pics along with a quick description.
First, I want to thank Funk for posting pics of both his own Dlator and a real one (yours too?) I also purchased a transformer from him which was most excellent. Small enough to fit on the back of the rack just like the originals.
Although I used Funk’s eyelet layout with minor alterations including eyelets being connected on the underside of the pwr board. I tried hard to get as close as possible to the original Dlator so I skipped the ground bus and instead sanded all corners to create a universal ground that way. I also added an 8-lug terminal strip above the power supply board so I didn’t have to elongate the pre-existing tranny leads. It was built using an 8” deep Hammond rack chassis, the PTFE coax is from Apex Elec and the 12AX7 is a balanced triode from EH. Labeling the enclosure was a breeze with my trusty DYMO labeler!
[IMG:1023:637]http://i205.photobucket.com/albums/bb17 ... lator1.jpg[/img]
[IMG:1024:676]http://i205.photobucket.com/albums/bb17 ... lator2.jpg[/img]
[IMG:1023:671]http://i205.photobucket.com/albums/bb17 ... lator3.jpg[/img]
[IMG:1024:642]http://i205.photobucket.com/albums/bb17 ... lator4.jpg[/img]
[IMG:1024:266]http://i205.photobucket.com/albums/bb17 ... lator5.jpg[/img]
[IMG:1024:238]http://i205.photobucket.com/albums/bb17 ... lator6.jpg[/img]
Last edited by UltraHookedOnPhonix on Tue Jul 22, 2008 6:36 pm, edited 2 times in total.
Re: Finished Dumblelator
Nice clean job! :D
How does it sound?
UltraHookedOnPhonix
Thanks!
Sounds fairly transparent but like I said, there's definately that phase inversion sound people have been talking about that is present.
I also think that the added In pot for the recovery stage is cool. Allows you really to fine tweak the gain recovery stage.
briane
Post by briane »
nice clean build! 8)
such nice lead dress almost looks like HAD would have built that one.
rutledj
Post by rutledj »
Just a quick question as I'm totally in the dark on how a dumblator works. Is it connected in the ckt via the preamp out/pwr amp in in the amplifier?
Rut
UltraHookedOnPhonix
Thanks briane! :D
That's correct rutledj.
jelle
Post by jelle »
That looks so nice!
Jelle
dogears
Post by dogears »
Extremely good work!! Neat and tidy. Plus you got the three knobber! Good show ;)
Tonefishin
Post by Tonefishin »
Nicely done!
UltraHookedOnPhonix
To all: THANK YOU!!!! :lol:
Really appreciate it.
It was a fun project. What took so dang long for me was preparing all that coax, wheeww!!! At least I didn't have to worry about melting the insulation that runs between the shield and center conductor because it's teflon.
Here's a schematic of the build I made:
[IMG:1023:563]http://i205.photobucket.com/albums/bb17 ... atic-1.jpg[/img]
Last edited by UltraHookedOnPhonix on Thu Feb 28, 2008 6:26 pm, edited 1 time in total.
Funkalicousgroove
Post by Funkalicousgroove »
Nice work!!
BTW, I made a mistake and that PT makes 135-0, not 135-135, so it only works properly on a voltage doubler :oops:
Beautiful clean work!
UltraHookedOnPhonix
Thanks Funk!
I changed the schematic to read 135V-0V.
Funkalicousgroove
You should give that Schemo to the guy from Schematic Heaven, it's a good one!
UltraHookedOnPhonix
Bombs away!!!!
In regards to the "original" Dlator schem, what specifically does the altered values do besides increase headroom and recovery gain? I mean, didn't the Dlator based on the initial schem run of a 12AX7 as well, yet we hear complaints of clipping issues?
heisthl
Post by heisthl »
Great Job! I bet it's quiet. Looking at your schematic I have 2 questions - 1. 1k3 ohm Carhode resistor on return? Is that a typo or do you have that value laying around? 2. Did you really interrupt the signal at both the send and return jacks or just the return. If both why? The send can be an excellent line out while still passing signal to the return.
www.RedPlateAmps.com
