6SJ7 Gain Factor Comparison
Magnatron
Post by Magnatron »
Where does the 6SJ7 pentode tube fall in the gain factor scale as compared to typical triode tubes?
Ten Over
Re: 6SJ7 Gain Factor Comparison
Post by Ten Over »
Magnatron wrote: Thu Feb 22, 2024 7:54 pm Where does the 6SJ7 pentode tube fall in the gain factor scale as compared to typical triode tubes?
Amplification factor?
Magnatron
Post by Magnatron »
Ten Over wrote: Thu Feb 22, 2024 8:06 pm
Yes. I'm looking for where it falls on the scale against triode preamps as a comparison. This isn't for anything in design, just wondering...
Ten Over
Post by Ten Over »
Magnatron wrote: Thu Feb 22, 2024 8:47 pm Yes. I'm looking for where it falls on the scale against triode preamps as a comparison. This isn't for anything in design, just wondering...
The 6SJ7 in pentode mode has a way higher amplification factor than the triode tubes we fool with. But the 6SJ7 also has a way higher internal anode impedance which needs to be taken into consideration.
didit
Post by didit »
Hello --
Search works -- 6SJ7 Pentode Operating Conditions.
Clearly the gain can be all over the map depending upon how the 6SJ7 (or any tube, for that matter) is set up. Typical 12AX7 with 100k plate load is ~35 dB. 6SJ7 in a 5C1 Champ, grid leak biased with 250k Ra, is probably close to 45 dB.
