For those who know Soldano, I see the two schematics on EL34world.com either power the PI off of “B1”—a node that doesn’t exist on the schematic—or “B2”, the same node that powers the CFs on both sides of the effects loop. Furthermore, the voltage drop listed from the screens to the PI node is about 120 VDC across a 10K resistor. Is there supposed to be a separate node for the loop and PI?
See here:
 https://el34world.com/charts/Schematic ... slo100.pdf
									SLO100 Power Supply
SLO100 Power Supply
Just plug it in, man.
Re: SLO100 Power Supply
The loop and the PI are powered from the same node, the one after the 10k, where the two preamp branches originate.
Thanks as always, Martin!martin manning wrote: ↑Sun Jun 11, 2023 8:14 pm The loop and the PI are powered from the same node, the one after the 10k, where the two preamp branches originate.
That amp is running those number 2 grids dam hard for not being UL!
The max stated design spec for a 6L6GC screen is 450 vdc.
yes, but with 1k screen resistors and typically sovtec 5881s? the power supply should sag some but not much here
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
