Hum in Bandmaster
Fender Amp Discussion
Oddvar R
Hum in Bandmaster
Post by Oddvar R »
Hi. I have a Bandmaster build that has this constant hum, the only thing that affects is the bias pot, it gets louder as the the value is towards -37. I have have basically tested everything, changed parts etc. The funny thing is that when I put in just one power tube, the hum goes away, with two it comes back.
Pin three on both PT's have about 479v, on the layout is said 440v. The transformer is a Hammond 290DEX, with 325/2 v on the secondaries. I wonder if that could be the wrong transformer?
I would appreciate som tip on this.
angelodp
Re: Hum in Bandmaster
Post by angelodp »
Do you have DC on the board? Are the 68k's on the jacks?
Oddvar R
Post by Oddvar R »
Yes---
LOUDthud
Post by LOUDthud »
Do you have a known good pair of tubes to try ? Can you try these tubes in a different amp ? Did you check the screen resistors ?
Post by Stevem »
Minus 37 is way too little for a bandmaster with 6L6 output tubes!
The schematic calls for -45 at the junction of the 220k resistors with 440 volts or so on the pin 3 of the outputs.
Your hum is the output tubes red plating .
If you keep running the amp like this your hum problem will gradually go away because you have killed the output tubes!
Oddvar R
Post by Oddvar R »
I am not having it on -37, I just say that when I turn the bias pot, that's the only time the hum increase or decrease.
How much ripple is on the bias voltage? Have you tried increasing the filtering on the bias supply? That solved the hum problem on a Bandmaster for Bombacaototal.
Oddvar R
Post by Oddvar R »
How could I do that? Increasing the uF values? Its 20uf / 70uf now?
What does your bias circuit look like now? Same as the original or something different? It's possible that the bias setting affects the hum simply because you are increasing or decreasing the current draw through the power tubes. Was it ever quiet? Are the filter caps in good condition?
Post by Stevem »
If you only have one output tube in either socket is the level of hum the same ?
Also like Martin asked, how much ac ripple voltage do you have on pin 5 of a output tube socket?
Post by Stevem »
angelodp
Post by angelodp »
Can you post some pics of your build.
Oddvar R
Post by Oddvar R »
martin manning wrote: Fri May 26, 2023 6:26 pm What does your bias circuit look like now? Same as the original or something different? It's possible that the bias setting affects the hum simply because you are increasing or decreasing the current draw through the power tubes. Was it ever quiet? Are the filter caps in good condition?
Same as the original. It might at one point have been quieter, I am not sure. I have bought ned tubes to see if that might have something to do with it. (The amp works though.)
The ripple on pin 5 I am not sure how to measure.
I have changed the filter caps to larger ones 47/100 uf, but no change.
Post by Stevem »
Ripple is a small ac voltage riding on a larger dc voltage so you set your voltmeter to ac to read it.
Which Bandmaster circuit is it?
