AC15 channel output difference
Vox and Hiwatt Discussion
plookit
Post by plookit »
Hello,
I made an AC15 chassis up about 10 years ago and never got around to completing it due to being overwhelmed with my teaching job, which I just retired from. I have dug out the AC15 and fired it up. It sounds great and need to get it in a cabinet.
One thing that concerns me though is the output difference between channel 1 (vibrato channel) and channel 2. Channel 1 is quite a bit lower volume than channel 2. Is this normal on an AC15?
sluckey
Re: AC15 channel output difference
Post by sluckey »
That's normal.
plookit
Post by plookit »
sluckey wrote: Sat Mar 25, 2023 12:39 pm That's normal.
That's good to know. Thank you.
sluckey
Post by sluckey »
You can make it much better by swapping positions with R10 and R35. Even better if you replace R35 with a jumper wire and change R10 to 62K. Refer to linked schematic. Easier to see what's going on if you look at page 3.
http://sluckeyamps.com/VAC15/Vox_AC15.pdf
plookit
Post by plookit »
sluckey wrote: Sat Mar 25, 2023 12:52 pm You can make it much better by swapping positions with R10 and R35. Even better if you replace R35 with a jumper wire and change R10 to 62K. Refer to linked schematic. Easier to see what's going on if you look at page 3.
That is brilliant, thanks so much. I'll let you know how I get on. What a superb set of documents.
plookit
Post by plookit »
I made those mods on R35 (jumper) and R10 (66 because not got 62) and channel 1 seems even quieter. Will reverse it and compare
sluckey
Post by sluckey »
I did not expect that.
And I should add... Looks good on paper but I have not done this to verify.
