Non-NOS component choices
WhopperPlate
Re: Non-NOS component choices
Post by WhopperPlate »
FUCHSAUDIO wrote: Tue Sep 20, 2022 6:25 pm Despite many companies exporting amps with the Dale RN65 resistors in them, as of today, they do still not appear to be RoHs compliant.
https://www.mouser.com/c/?q=dale%20RN65%20resistor
Aren’t the CMF series essentially more or less the same as the RN? Or is this a new “non magnetic” series different than usual? It’s listed new on Mouser . ROHS compliant.
Charlie
ViperDoc
Post by ViperDoc »
Some very good info here. Applying this to currently available filter cap values, is there a consensus on suitable replacements for 300uF 350V filter caps? I see the #124 schematic listed here shows the filter cap node with two 300uF 350V caps in series for a 150 uF 700V net. If #102 has two 220uF 300V for a 110uF 600V outcome, perhaps this is suitable (and not blasphemous :shock: )? Thanks.
Just plug it in, man.
WhopperPlate
ViperDoc wrote: Thu Sep 22, 2022 3:17 pm Some very good info here. Applying this to currently available filter cap values, is there a consensus on suitable replacements for 300uF 350V filter caps? I see the #124 schematic listed here shows the filter cap node with two 300uF 350V caps in series for a 150 uF 700V net. If #102 has two 220uF 300V for a 110uF 600V outcome, perhaps this is suitable (and not blasphemous :shock: )? Thanks.
Close but not exact… ARS capacitors come in 270uf @ 450vdc radial can and 400vdc snap in …good caps with long life
Edit: they say they are out. Waiting on reply whether they will ever be in .
Edit: only available via bulk OEM orders
Charlie
WhopperPlate
I remember way back, I was going to convert an old Fender Bassman to a dumble ODs (long story but it got cut short ) .
When I first saw the 300uf caps in the schematics and I couldn’t find any easy replacement , I was just gonna pack the doghouse on the fender with x6 100 uf spragues I had lying around.
Lol when I finally got around to building an ODS in a standard size chassis , remembering how much room they occupied I did think about stacking them like a trainwreck and making a glue castle, but I conceded at 220uf instead lol .
I still have those 6x sprague all glued together in a box somewhere :lol: I will reform and put ‘em to use eventually
Charlie
ViperDoc
Post by ViperDoc »
WhopperPlate wrote: Thu Sep 22, 2022 8:09 pm
It's no wonder that future versions (and maybe more with cloners) have resorted to radial capacitors for easier real estate, but they're not easy to find either.
WhopperPlate
ViperDoc wrote: Thu Sep 22, 2022 9:06 pm
Yes! Finding acceptable non nos components has practically always been an evolving dilemma
Charlie
bepone
Post by bepone »
epcos, nichicon, kemet, UCC, Miec and so on, are making caps for 600V and are not expensive, time to go in this way..and use only 1 cap instead of 2 in series..
WhopperPlate
bepone wrote: Fri Sep 23, 2022 10:44 am
Or we can all pitch on a bulk order of the only axial cap left :lol:
https://www.digikey.com/en/products/det ... yTPmKVy5UA
what’s your fav there Bepone?
Charlie
dorrisant
Post by dorrisant »
WhopperPlate wrote: Fri Sep 23, 2022 3:26 pm
Haha... very funny!
WhopperPlate
dorrisant wrote: Fri Sep 23, 2022 5:20 pm
Haha... very funny!
That’s a whopping 26 amplifiers ! Unless there’s a dud :D
Charlie
bepone
Post by bepone »
WhopperPlate wrote: Fri Sep 23, 2022 3:26 pm what’s your fav there Bepone?
until now for elcos massively /without any defect in 15 yrs UCC KMG, and often also popular F&T..
from 600V i didnt any, but it is a time now, how they are developing.. no sense to waste money in sprague/ 2 in series :P
WhopperPlate
For all the Draloric lovers , how do you feel about the current offerings?
https://www.mouser.com/ProductDetail/Vi ... 2FYw%3D%3D
Charlie
WhopperPlate
bepone wrote: Fri Sep 23, 2022 6:32 pm
It’s all a matter of what is considered a waste. I still can’t find any other capacitor that sounds exactly like a sprague…or a F&T for that matter . Neither are my personal favorite , but if that’s what you want to hear then that’s what you want to use. Good luck trying to find anything that sounds like the old Daly caps in Marshalls …
Charlie
WhopperPlate
i shared this search list in another thread. Felt it was a good link to share here concerning finding modern available Carbon films for the B+ string .
https://www.mouser.com/c/passive-compon ... r%20Rating
Charlie
WhopperPlate
Was thinking about other Non nos parts I have tried, and one interested power resistor were the Mills non inductive resistors . Expensive , but tank like ratings and it was pretty startling how swapping it into the b+ line determined the response of the amplifier .
Again , kinda like the takman effects on the signal path , I felt like I was under the magnifying glass . The amplifier slapped me around , felt like it had more output power because of the lack of distortion , not as bouncy and gainy, but the dimension was crazy . Not brittle , but wow was it loud in my ears and head . Stout was a word used to describe it .
That amp wasn’t mine, so it was changed to deliver a softer sound, but it’s something I want to try out again Soon.
Charlie
