Back to that noisy reverb
glasman
Re: Back to that noisy reverb
Post by glasman »
Per chance is it motorboating due to positive feedback. The 10K tap resistor does not provide much insolation. If the input and output are in phase it is possible that you are getting an oscillation.
Try reversing the wires on one side of the transfomer.
Gary
About 5 miles south of I-94
www.glaswerks.com
MarkB
Post by MarkB »
Bob-I wrote:
mlp-mx6 wrote:Could it be the shared cathode to ground, with other paths to ground in between? What if the V3b (the 2nd recovery stage) cathode had its own bias resistor (and optional bypass cap)?
I'm thinking the shared cathode is setting up a nice ground loop there, in parallel with the internal resistance of the tube, perhaps.
Well, I tried it, no change. Damn this is frustrating.
Time to pop for an o-scope?
mlp-mx6
Post by mlp-mx6 »
Do you have another reverb tank to try it with? (perhaps the problem is the tank?)
Bob-I
Post by Bob-I »
glasman wrote:Per chance is it motorboating due to positive feedback. The 10K tap resistor does not provide much insolation. If the input and output are in phase it is possible that you are getting an oscillation.
Gary
Tried .... didn't help
No I don't think it's a feedback issue. Somehow I'm getting noise on the input of this stage.
Normster
Post by Normster »
Mostly OT, but I saw Paul Rosk on ampage offered to do a partical realignment on your caps for only $20 each! LMAO :D
groovtubin
Post by groovtubin »
Normster wrote:Mostly OT, but I saw Paul Rosk on ampage offered to do a partical realignment on your caps for only $20 each! LMAO :D
Now THATS funny!! jim
Bob-I
Post by Bob-I »
What????? that's not worth the $20???
I thought it was a good deal. :shock:
