Mojotone SR Chassis Dimensions
EstimatedAntelope
Post by EstimatedAntelope »
Does anyone have a drawing file for the Mojotone SR chassis? I have one on the bench and need faceplates made, but I'm only using some of the holes. Their tech support is being illusive to giving me the full drawing file.
I realize that all of these companies tweak these a bit so I want the actual drawing and not some generic SR layout.
Colossal
Re: Mojotone SR Chassis Dimensions
Post by Colossal »
Can you just measure the hole and cutout centers yourself and make a drawing or are you graphically challenged?
EstimatedAntelope
Colossal wrote: Mon May 09, 2022 7:05 pm Can you just measure the hole and cutout centers yourself and make a drawing or are you graphically challenged?
I'm more than graphically challenged...
In reality, I'm tight on time and my buddy has time at his shop on their laser cutter / engraver so he's pressuring me to just send him a file...hence the ask.
Colossal
Post by Colossal »
EstimatedAntelope wrote: Tue May 10, 2022 4:36 pm
If you can measure your faceplate and show the centers for the holes you want and where, I can help you out with a PDF.
EstimatedAntelope
Colossal wrote: Tue May 10, 2022 8:09 pm
I actually caught a lull in work insanity and had time to sit down and sketch it out for him to export as a .dxf. Took me a few weeks but I got it done. I guess his shop was delayed and his McMaster order was delayed too so it worked out.
Appreciate it though
Austen
