More Log for Fender Tweed Deluxe Volume Pots
Anyone know what pots were used in the Fender Edge Tweed Deluxe?
Re: More Log for Fender Tweed Deluxe Volume Pots
Any reason to suspect that their values are not the original ones?
I see no reason why the pot values would have been changed & even less for which ones.
Apart from the expensive speaker, tighter bottom end than the original sounds like more filtering (through smaller filter caps) and beefier output transformer, to me. I might be wrong, though.
Do you have a issue with the volume pot in the edge?
I recall seeing a 5% taper spec on some Fender schematics, which might satisfy the ‘more log’ criteria?
My bad! Now I figure myself the "more log" ...
So that would mean the "The Edge" one has "normally bad"(*) log pots, while the vintage one had some (good) 5% taper ones?
___
(*) https://guitarnuts2.proboards.com/threa ... llTo=84298
___
I just read some comments about tweed volume pots. It mentionned that some pots, with a less steeper curve would allow for better dialing the volume at low levels, on the edge of breakup.
Then I remembered this post and felt like I've been overlooking that point.
This curve (from https://guitarnuts2.proboards.com/threa ... llTo=84298 ) suggests that the CTS pots would allow for a better response than the alpha I've been using, notably.
Any additional comments - example given: about an even better solution?
pdf64
For the past couple of decades at least, CTS have been just crap, an absolute joke, the elongated metal CCW track end means that 20% of the mechanical rotation produces no electrical change.
The benefit for CTS is that the same track can serve for pots with a rotary on/off switch. Yay, cost saving!
The downside is that every other pot doesn’t respond until it’s rotated more than 20%. Boo, previously great company brought down by penny pinching.
I only use CTS when no other option is viable, eg pull-push pots.
professormudd
Man, that explains quite a bit. I did a D-Lite and used all CTS pots and I thought they behaved really weird and it was very frustrating.
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
I found another schematic on the web, which shows a step in the response of a CTS pot, in the last degrees of rotation. That is consistent with your gutshot of a CTS pot...
