OOPS!! Yes Senior moment
 Thank you for clarifying. I have some ideas about increasing the gain the first stages of the clean channel and I'm going to tinker with the load resistors in the power section, too (preamp voltages are all on the conservative side). I've been focusing on the PI for a while because I've been looking for a balanced output and I know that a slight imbalance there can boost the second harmonics which seem to be an essential element in the formation of bloom. First job is to replace the 5k pot with a 10k and then the reduce the plate resistors to give the pot a bit more of a say in proceedings, and then start tricking out the PI looking for any improvements it might bring. There's nothing essentially wrong with the sound of the amp [wish I had easy access to some recording gear - it's so hard to characterise!] but I "just know", this amp has more to offer. I see playing with the resistors as a fairly benign and easy thing to do and it seems unlikely to do any harm... Altering the load lines in the PI in this way might be all it takes, it seems to have limitless headroom, maybe it just needs a little less.. but with more gain. The question of NFB (local and global) wasn't something I thought of until we started thinking about the snubbing cap in the Bluesmaster circuit but this deserves further experimentation I believe.talbany wrote: ↑Sat Nov 20, 2021 6:29 pmStevenStephen1966 wrote: ↑Sat Nov 20, 2021 4:32 pm "Loosen it up," "sterile," - stiff... yeah. Regarding the second generation thread, I think you might be overestimating my intelligence on these matters, Tony! I mean, it's an interesting comparison but so much of Ben's sound is in his playing... I worked through the 3rd generation schematic which I understand is close to your 2nd gen layout, and there are a lot more design changes there, than I would care to attempt with my amp, GNFB, power section and so on... I think we all appreciate how you elaborated on this though.
The notes I'm finding are beautiful and complex, I'm sure a Jazz musician would love it. I'm just looking for something a bit more... unrestrained, and definitely more bloom. Marshall-esque? Maybe not, but... Because even if I hammer it with the volume at stadium levels the amp kind of just sits there like a forlorn Fender. The notes just don't reach out and grab you, the fundamental doesn't swell, at least not very much, and not in the effortless way the amps in the clips do.
I'm putting together a shopping list now, so thank you for the heads up. I'm not too interested in going all the way down that rabbit hole, I'm just being nosy: I want to know what's going onI don't have any reservations about using CFs in this part of the signal chain, but I'm ordering MFs as well. For both Bluesmaster and #183 style PI's. IIRC, the early incarnation of the #124 was more akin to the #183. The components are cheap enough and the swap on these boards is easy enough. Worth a try.
So I think there were a few things that were either mistranslated or misinterpreted!
The comment about the 2nd Generation/Bluesmaster in my 1st post was to simply illustrate some of the different sound characteristics of each of the PI's used in the ODS model amplifiers inherent to the design and not the parts!, since that's what I thought you were asking about (Phase inverters) So to avoid any misunderstandings here! When I talk about resistor types/brands I am talking about nuances or small changes in sound and not the things you described in the your last post to me (unrefined, Bloom). This is clearly something else going on with the amp and I don't think your cure is in your resistor types. Sorry for any confusion!
BTW..Your amp will be even more complex to diagnose here because it is a one of a kind and you didn't follow the layouts in the files section, hopefully you can get squared away!
Thanks! Great advice, I'll have a think about it... It would be easy to implement the way you suggest. Rather than reducing the resistance of the 4.7k resistor (assuming this is the one you mean), I'm curious what the effect of increasing it would be. Increasing high frequency distortion?ijedouglas wrote: ↑Sat Nov 20, 2021 6:55 pmI'm pretty sure the GNFB is on the 4 Ohm tap.Stephen1966 wrote: ↑Sat Nov 20, 2021 6:15 pm
It's actually the cleans which are bugging me more than the OD, I like the growl I get from the OD and as long as its not set too high, I get good note definition in power chords there.
The Bluesmaster - if we include the presence pot as well - has a NFB total resistance of close to 130k, the 183 and 124 is about 7k though in the 183 schematic I'm looking at the NFB is tapped off the 8ohm lead - I think that might be a mistake, Tony's layout shows it tapped off the 4ohm lead.
https://tubeamparchive.com/viewtopic.php?f=5&t=13095
I was lifting the NFB earlier last week to double check I had the OT wired up correctly - I didn't think to run a sound check then. Honestly, it's a bit of an ordeal to solder and unsolder but I could put a switch on the bottom of the chassis for it. I'd rather not dispense with it completely.
How would you go about testing the NFB values?
To test the GNFB, you can either replace the resistor with a 5K pot or just swap out values, should be pretty simple.
To test the LNFB, just lift one of the 10M resistor legs.. or put it on a switch.
The other thing I would highly recommend, is to let the amp settle and break-in a little. Give it 100 hours and see if it is still not to your liking.
Yup, 4K7 resistor. Actually, I got it wrong, you would want a bigger pot there as you would want to try increasing the value. More resistance == less NFB == more lively. Maybe a 10KStephen1966 wrote: ↑Sat Nov 20, 2021 7:41 pm Thanks! Great advice, I'll have a think about it... It would be easy to implement the way you suggest. Rather than reducing the resistance of the 4.7k resistor (assuming this is the one you mean), I'm curious what the effect of increasing it would be. Increasing high frequency distortion?
Appreciate the insightijedouglas wrote: ↑Sat Nov 20, 2021 7:46 pmYup, 4K7 resistor. Actually, I got it wrong, you would want a bigger pot there as you would want to try increasing the value. More resistance == less NFB == more lively. Maybe a 10KStephen1966 wrote: ↑Sat Nov 20, 2021 7:41 pm Thanks! Great advice, I'll have a think about it... It would be easy to implement the way you suggest. Rather than reducing the resistance of the 4.7k resistor (assuming this is the one you mean), I'm curious what the effect of increasing it would be. Increasing high frequency distortion?
I have an AN Wonderland I built a while back that I put both GNFB and LNFB on switches. It definitely livens up the amp when removing the GNFB
Complementing what Ian said, this sounds like a good idea. I was thinking "what if I made a little PCB?" but no need. Your way is better. The pot could be substituted with the decade box. I would just need to watch for that whiff of burning resistorstalbany wrote: ↑Sat Nov 20, 2021 7:00 pmThe layout is correct 183 used the 4 ohm tap not 8 ohm. (Less GNFB)The Bluesmaster - if we include the presence pot as well - has a NFB total resistance of close to 130k, the 183 and 124 is about 7k though in the 183 schematic I'm looking at the NFB is tapped off the 8ohm lead - I think that might be a mistake, Tony's layout shows it tapped off the 4ohm lead.
On twin iron he used 8 ohm tap
BTW..An easy way to check GNFB is to take a 10k 15k pot wired as a variable resistor one lead to the NFB resistor and the other to the tap. You can then adjust the pot to the setting that works best then measure the pot value and replace the GNFB resistor to that value.Just make sure your presence control still works with that value.
StevenStephen1966 wrote: ↑Sat Nov 20, 2021 7:24 pmThank you for clarifying. I have some ideas about increasing the gain the first stages of the clean channel and I'm going to tinker with the load resistors in the power section, too (preamp voltages are all on the conservative side). I've been focusing on the PI for a while because I've been looking for a balanced output and I know that a slight imbalance there can boost the second harmonics which seem to be an essential element in the formation of bloom. First job is to replace the 5k pot with a 10k and then the reduce the plate resistors to give the pot a bit more of a say in proceedings, and then start tricking out the PI looking for any improvements it might bring. There's nothing essentially wrong with the sound of the amp [wish I had easy access to some recording gear - it's so hard to characterise!] but I "just know", this amp has more to offer. I see playing with the resistors as a fairly benign and easy thing to do and it seems unlikely to do any harm... Altering the load lines in the PI in this way might be all it takes, it seems to have limitless headroom, maybe it just needs a little less.. but with more gain. The question of NFB (local and global) wasn't something I thought of until we started thinking about the snubbing cap in the Bluesmaster circuit but this deserves further experimentation I believe.talbany wrote: ↑Sat Nov 20, 2021 6:29 pmStevenStephen1966 wrote: ↑Sat Nov 20, 2021 4:32 pm "Loosen it up," "sterile," - stiff... yeah. Regarding the second generation thread, I think you might be overestimating my intelligence on these matters, Tony! I mean, it's an interesting comparison but so much of Ben's sound is in his playing... I worked through the 3rd generation schematic which I understand is close to your 2nd gen layout, and there are a lot more design changes there, than I would care to attempt with my amp, GNFB, power section and so on... I think we all appreciate how you elaborated on this though.
I am likely to be confused about these things, its true - this is my first time round the block - but please don't think I don't appreciate your ideas. The devil is often in the detail and I'm into the nuances... as Richard said, "all the details matter."
More complex? Sure. I totally get it. But almost all complex tasks can be broken down into small steps, the PI is just one of the small steps. I haven't even gotten to the reverb or the FX loop yet
 talbany wrote: ↑Sat Nov 20, 2021 8:24 pm ... Thanks for the rundown makes perfect sense now I wish we would of had this discussion earlier. After being here forever you are not alone as I have seen many posts here where some builders have asked the same thing? where is the crazy note bloom this thing is famous for. I can just tell you that I've built some amps where the notes just don't want to bloom as well as others do! and there is this one... https://www.youtube.com/watch?v=qyB4HedEOvs
https://ampgarage.com/forum/viewtopic.p ... dback+city
that bloomed into feedback on just about every note,so don't beat yourself too much about it. Do your best to get it balanced, voltages set and get the GNFB and break the thing in..
PM me if you have any other questions!
Out of here
   Wow! This is like an episode of the Twilight Zone... I'm going to enjoy this.
Indeed, very consistent.ijedouglas wrote: ↑Sun Nov 21, 2021 5:47 pmLooking at various gut-shots HAD was pretty consistent with the values of his dropping string. I may be way off on this one but it has worked for me.
Correct. It’s making a LPF with the tube’s grid capacitance. 22k will admit more HF than 33k, but the corner point for 33k is already about 48 kHz.ijedouglas wrote: ↑Sun Nov 21, 2021 5:47 pm Regarding the V1a grid resistor. I'm not sure you do much for the gain by going from 33K to 22K. ... I think this may change the tone more than the gain.
Ian - rolling tubes, I like that idea. For a start, I could swap the Cl and OD tubes and see if that works to bring them into a better balance, but I have some other 7025s and 12AX7s knocking around. I could try those... any solution that doesn't require soldering has to be goodmartin manning wrote: ↑Sun Nov 21, 2021 6:47 pmIndeed, very consistent.ijedouglas wrote: ↑Sun Nov 21, 2021 5:47 pmLooking at various gut-shots HAD was pretty consistent with the values of his dropping string. I may be way off on this one but it has worked for me.Correct. It’s making a LPF with the tube’s grid capacitance. 22k will admit more HF than 33k, but the corner point for 33k is already about 48 kHz.ijedouglas wrote: ↑Sun Nov 21, 2021 5:47 pm Regarding the V1a grid resistor. I'm not sure you do much for the gain by going from 33K to 22K. ... I think this may change the tone more than the gain.
