DELUXE REVERB NORMAL:LEAD CHANNEL MODS
Fender Amp Discussion
ViperDoc
Post by ViperDoc »
I've seen several recommendations of putting a "Plexi"-style Lead circuit into the Normal channel of a Deluxe Reverb, but I can't find very many examples that show how to make it sound its best. Only examples I've seen sound quite thin. Considering the Normal Channel only has two triodes, would you recommend adding another gain stage? i.e. extra tube?
Just plug it in, man.
sluckey
Re: DELUXE REVERB NORMAL:LEAD CHANNEL MODS
Post by sluckey »
You don't need another gain stage. You need a cathode follower. The CF can easily be replaced by a MOS-FET.
Or, if you just gotta have a tube CF, you can do a simple mod to the two triode tremolo circuit. The Trem-O-Nator only uses one tube, thus freeing up a triode, and it sounds much smoother and stronger than the original Fender tremolo. I considered doing this to my Bandmaster but kinda fizzled out after the Trem-O-Nator mod.
Either way, you can easily get a single channel Plexi preamp. But it's still gonna be connected to an AB763 power amp driving a Fender sounding speaker. Probably not gonna be the last amp you ever build. :mrgreen:
ViperDoc
Post by ViperDoc »
I'll check that out, thanks, Sluckey.
I've never used a MOSFET outside a 5VDC power supply. How would it be used?
ViperDoc
Post by ViperDoc »
ViperDoc
Post by ViperDoc »
I drew up a few variants of a possible mosfet CF. Which of these is the best way to design it? I've only seen the CF used pre-tone stack in Marshall-style circuits.
For your entertainment:
[DELETED]
sluckey
Post by sluckey »
None of those look like a plexi. Plexi topology goes---> input-gain-volume-gain-CF-TS-PI.
pdf64
Post by pdf64 »
A MOSFET equivalent isn’t going to cause the waveform asymmetry that is a notable characteristic of a DCCF though.
http://www.valvewizard.co.uk/dccf.html
ViperDoc
Post by ViperDoc »
sluckey wrote: Thu Jun 24, 2021 11:37 am None of those look like a plexi. Plexi topology goes---> input-gain-volume-gain-CF-TS-PI.
Good point. I'll get back to the drawing board... My main question is where to put the MOSFET in the circuit, although you may have just answered that.
sluckey
Post by sluckey »
ViperDoc wrote: Thu Jun 24, 2021 2:34 pm
Look at a plexi schematic. Locate the CF. Replace with the MOSFET.
Ten Over
Post by Ten Over »
Here are a couple of examples of the Normal channel modded into a somewhat Marshall topology.
ViperDoc
Post by ViperDoc »
Here's another go:
[DELETED]
ViperDoc
Post by ViperDoc »
Ten Over wrote: Thu Jun 24, 2021 10:34 pm Here are a couple of examples of the Normal channel modded into a somewhat Marshall topology.
Very nice, thanks for those files, Ten Over. I like how the second mixes both channels into the reverb. I wonder how you could design a Lead Channel Reverb level. Most likely a relay? I thought I also saw a Tremo-o-nator...
pdf64
Post by pdf64 »
ViperDoc wrote: Fri Jun 25, 2021 4:36 am Here's another go:
AB763 LEAD 2.0.pdf
C? isn’t needed, and such a low value will mess up the expected response of the tone stack controls.
ViperDoc
Post by ViperDoc »
pdf64 wrote: Fri Jun 25, 2021 7:34 am
AB763 LEAD 2.0.pdf
Thanks. I assume you mean the .0022 cap off of the cathode follower? I simply copied the tone stack from a Super Lead schematic. The drawings from Ten Over raised another question I had, which was whether to increase the value and/or number of power supply caps in the Lead circuit. The stock AB763 uses a single 16 uF power supply capacitor for four preamp triodes. I suppose you'd only be using two at a time, perhaps that's enough.
pdf64
Post by pdf64 »
ViperDoc wrote: Fri Jun 25, 2021 5:39 pm ...I assume you mean the .0022 cap off of the cathode follower? I simply copied the tone stack from a Super Lead schematic...
I can't think of any SuperLead with such a cap feeding its tone stack?
