Dogears thanks for the note... you've got my attention with your ability to squeeze tone out of these things. I'll be attending to your suggestions and getting the voltages on the mark ASAP.dogears wrote:RJ,
Check your presence circuit. The D'Lite layout is wrong. Make sure your presence circuit is wired the same as Dumble did it. Do not take the third lug of the presence pot to ground. Only ground the cap and tail resistor. Also, use the 4.7K feedback resistor.
My advice stands. Do not use modified schematics unless you are cloning a specific amp. The D'Lite values are based on Norm's preferences for a 22 watt 6V6 amp, with certain transformers. That is not what you are building.
You should baseling to known good Dumble values and tweak from there.
The miswired presence will make the amp a whole bunch more raw.....
From my picture below you can see that I have the presence to ground on the third lug. Changing that as you suggested will be my next tweak and I'll check that resistor value too.
As I've changed a couple things it's now up to decent sounding clean and O.K. in OD... but still off the mark a bit overall.
I've got to go back to work (my day job) now but tonight I'll make the presence wiring changes and see what is up.
I can now get the volume and trimmer turned up pretty high before the squeal sets in and the OD tone has potential for being satisfactory.
I've got to go back and check that OPT wiring and carefully go over the OD circuit... something is just a bit off yet and that squeal is trying to tell me something??
thanks for the help... keep sending the suggestions.
rj
