Bob-I wrote:Actually, I decided to try reducing the gain first. The 2 extra components, the coupling cap and series resistor look good, but it would require I change my layout. I'll try lowering the first return load resistor to 22K, then the second to maybe 47K. I believe that should address the reverb balance.
Bob, I was going over that lack of coupling cap and I think there could be some serious potential problems.
Looking at the plate of the second recovery amp I am guessing that there is somewhere around 190 volts on the plate. If you follow that back in the circuit to the relay it is going to put 160+ volts on the Clean Master Pot and OD level pots. If you turn the master or OD to zero, that 160+ is going straight to ground through the pot.
Put the amp in Clean D mode and measure the DC voltage on the wiper. Also try it in OD mode and measure the OD level wiper to ground, I bet you will see a pretty high voltage there, of course this is just my 2 cents.
Gary
About 5 miles south of I-94
aka K0GWA, K0 Glas Werks Amplification www.glaswerks.com
Gary
Yes, it's over 180V, that explains the scratch on the pot. Coupling cap going in.... thx.
In another thread the "too much reverb" issue came up. Gary suggested using a dwell control or voltage divider on the input of the driver amp.
I tried several things today. First a 470k / 470k divider which only dropped the reverb a little, so instead of having the reverb control on 1, I could put it to 1.5
Next I changed the divider to 220k/820k, better but still not exactly right.
Finally I took a 500k mini pot and soldered it in. Yes the load should be 1M but I don't have a 1M pot small enough. This seems to be the trick, a dwell control is necessary. I'll source out a small 1M pot but for now the 500k is staying in.
