And do you have any valves in the amp when testing this circuit? If not, you’ll definitely need a bleeder resistor.martin manning wrote: ↑Fri Jul 24, 2020 6:14 pmLittlewyan makes a good point. Are you measuring with standby set to play, and if not, is there a bleeder resistor across the reservoir cap?Littlewyan wrote: ↑Fri Jul 24, 2020 3:18 pmJust a quick note, I recall when I used this circuit in one of my amps that I had to be careful with the standby switch. I can't remember the exact issue, but a paragraph on Merlin's site explains it well:
Notice that this charging path includes the HT load represented by R3. This means that before the valves have warmed up, there will be no bias voltage present unless you have a bleeder resistor across the HT.
Can you draw out the original low voltage and bias circuit?
I thought I had this figured out...
- Littlewyan
Re: I thought I had this figured out...
His meter is averaging the mostly positive pulses at the junction of the diode and cap. It is an ac waveform but the zero volt baseline is shifted way down such that the waveform is mostly positive with only a small negative portion. Even my Fluke 87 thinks it's dc if the meter is set to dc mode. Look at the scope pics in the link I posted. Should be apparent.Littlewyan wrote: ↑Fri Jul 24, 2020 9:33 pm Spot on. Although dorrisant is getting very weird readings. I don’t think they should be reading any dc between the cap and diode.
AC and DC after the cap look fine, but it still seems you have a very low DC resistance to ground after the diode. What do you measure?
- dorrisant
Late as usual... here's some pics.
This is an old hand drilled board I used because it was in the drawer and I've used this Merlin ckt before with good results.
Keep in mind, the 10k from pot to ground was removed so it could be probed with a decade box.
- dorrisant
Phone is giving me fits...
Now on the computer. Can't post these two pics. WTF?!?!
Tried to post like 20 times. keep getting this:
"ERROR
It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct."
Whatever, this site has been doing this to me quite a bit lately. Getting a bit sick of it.
They are not too big... 2.5 MB and 2.8 MB.
Some things are just cursed. This is how it has been with every turn with this shit amp.
"ERROR
- pompeiisneaks
- Site Admin
That almost sounds like it's trying to link to an external image instead of a locally uploaded one. If you use the 'image' tag but it's a webpage it will give that kind of error. It has to be an actual image link.
.jpg or the like.
.jpg or the like.
- dorrisant
Understood. But two pictures, no problem. Two others are giving this error. All four taken at the same time with the same device. All four were uploaded at the same time. Only two work. Emailed all four to myself. Still no dice on the two. The same two that were already posted will upload without issue... just to test theory/troubleshoot. Renamed them - no go. Tried to PM them to you. That ain't working either. Email address?
- dorrisant
Preamp tubes are in, no power tubes.
All plate voltages look about right for said conditions.
Less words... More pictures.
What do you know... this one works!
- pompeiisneaks
- Site Admin
Can you send them to me via email? I'll see if I can figure it out.
- dorrisant
Thanks Phil.pompeiisneaks wrote: ↑Tue Jul 28, 2020 1:47 am Can you send them to me via email? I'll see if I can figure it out.
Sent.
- pompeiisneaks
- Site Admin
So I've figured it out. There's a bug in this version of phpbb for jpg files if they have mismatched exif data for the image dimensions... basically, there's no easy fix, unless you save as a non jpg format. Or edit the exif data and fix or remove the size data.
/sigh.
I tried converting to png but the files are now too big.
I'll have to try resizing them as well.
/sigh.
- pompeiisneaks
- Site Admin
there you go.
- Littlewyan
1. Are you testing this circuit with the standby switch on?
2. What's the purpose of R3 and D1?
3. Do you actually mean -1VDC at output?
4. Is that solder built up on the negative end of C1? What measurement do you get if you measure resistance to ground from that point?
See here: http://www.valvewizard.co.uk/bias.html second schematic from the top of the page.
- Littlewyan
Ah thanks Martin. Can't remember if I implemented that on mine....
