Chassis Specifications:
Material: 3mm thick 5754 H111 Aluminum - High conductivity and extremely good corrosion-resistant qualities.
Bend Radius: 3mm
Overall Chassis Dimensions: 603,3mm x 204,5mm x 63,5mm
127mm Chassis mount spacing. I found a fabricator to work with for a headshell, https://www.elfring-amps.com/nl/
Welded vertical supports (this thing will NOT flex at all if you twist it
Optimized for PCBs (no drilling required!) and still compatible with the point-to-point eyelets Ryan designed and Hoffman Amps makes
https://el34world.com/Forum/index.php?topic=24843.0
This run of chassis are powdercoated with black silkscreen markings and fonts that looks like #002 without the "Dumble"name.
-Powdercoated finish chassis, with silkscreen artwork - €275
-SSS #002 PCB set designed by me- €150
-Shipping costs are variable in the current world market. For details PM or e-mail : info at e-noize.nl (for spam reasons you can figure out the @ )
-Note to US and other non-EU customers; I can ship worldwide, the chassis have blank voltage and fuse markings!
-Latest run have IEC adapter cutout, the original AC inlet is obsolete and not useable outside the USA.
-Latest run have mounting holes compatible with the mk1000-3 anchor nuts.
-Latest run has a optional pcb for a bipolar bias voltage suppy(for the cathode driver tube), this is not-tested yet! Only on request and at your own risk.
Layout and schematic: https://ampgarage.com/forum/viewtopic.p ... 67#p431767
Erwin
