Komet 60 Schematic...Accurate ?
Re: Komet 60 Schematic...Accurate ?
Post by Mark »
Looking at the three amps based on the #002 amp the first thing I noticed was the tube count one had four pre-amp valves another had six pre-amp amp valves while Aaron's amp had seven pre-amp valves. I also noticed that only one amp used an inductor for the filters.
I had a look at the Ceriatone amp, it has five pre-amp tubes and appears to have an inductor as there are two small transformers on the chassis.
From what we know which of the #002 amps can we rule out, they can't all be correct.
Yours Sincerely
Mark Abbott
They are all custom SSS amps, an interpretation of the builder.
Post by Mark »
So we don't have pictures or an accurate circuit diagram?
I thought I had something and this was it, pretty pitiful eh! :cry:
EDIT: I've noticed the closed thing we have is the Ceriatone SSS circuit.
Yours Sincerely
Mark Abbott
drampaz79
Post by drampaz79 »
Hi. Anyone can send me KOMET 60 schematic (Mark Knopfler LINDA)?
Thanks.
drampaz79@gmail.com
Roe
Post by Roe »
drampaz79 wrote: Tue Jun 16, 2020 8:04 pm Hi. Anyone can send me KOMET 60 schematic (Mark Knopfler LINDA)?
Thanks.
drampaz79@gmail.com
like a standard k60 except:
-5881s
- 220k plate resistor on the cold (3rd) gainstage
- 100k bias splitters instead of 220k
for k60, see https://ampgarage.com/forum/download/file.php?id=39517
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
drampaz79
Post by drampaz79 »
Thanks! please can you indicate me on the layout where are these 3 mods for KNOPFLER LINDA VERSION of komet 60?
drampaz79
Post by drampaz79 »
Roe wrote: Wed Jun 17, 2020 7:28 am
Thanks.
drampaz79@gmail.com
-5881s
Roe
Post by Roe »
drampaz79 wrote: Wed Jun 17, 2020 9:47 am
Thanks.
drampaz79@gmail.com
-5881s
replace:
- el34s with 5881s
- 220k bias splitters (connected to pin 5 of the output tubes) with 100ks
- 100k v2 anode resistor with 220k
4x12" w/H75s
drampaz79
Post by drampaz79 »
Roe wrote: Wed Jun 17, 2020 11:58 am
-5881s
replace:
- el34s with 5881s
Thanks a lot! Theese mods LINDA For knopfler komet 60 is from official source?
Roe
Post by Roe »
search the forum for the source
4x12" w/H75s
drampaz79
Post by drampaz79 »
Roe wrote: Wed Jun 17, 2020 3:39 pm search the forum for the source
Sorry...i don t understand...i would to know where do these indications come from and are safe because I think LINDA only has knopfler ... in the sense it is an interpretation or someone knows for sure that Linda is like this ....
drampaz79
Post by drampaz79 »
Hi. Anybody has specific for PT, OT CHOKE for komet 60? Thanks
Post by Mark »
Allynmey could tell you the Heyboer transformer set to order. It should be in this site somewhere.
Here is the link about the Mark K mods.
https://ampgarage.com/forum/viewtopic.p ... met#p80226
Yours Sincerely
Mark Abbott
drampaz79
Post by drampaz79 »
Mark wrote: Thu Jun 18, 2020 10:26 pm Allynmey could tell you the Heyboer transformer set to order. It should be in this site somewhere.
thanks!
Roe
Post by Roe »
drampaz79 wrote: Wed Jun 17, 2020 8:20 pm
MK mod is described here:
https://tubeamparchive.com/viewtopic.php?t=7665
and it basically consists of:
"Replace the two .02uF PI Caps with .047uF OD's
Replace the two 220K PI>power tube grid/bias resistors to 100K
Change the V2 Plate resistor from 100K to 220K
There you go. Bias it a little hot."
Power tubes used are 5881.
4x12" w/H75s
