Tolex glue
Aurora
Re: Tolex glue
Post by Aurora »
Wilsonart H2O is a waterbased contact glue... there's probably several other brands available in the US.... I've used swedish made Casco for making several styrofoam boxes for insulating electronic instruments..
jaysg
Re: Tolex glue
Post by jaysg »
I tried the water based stuff and found that it pulled up at edges. Maybe there's a technique to it. I now stick with Gel formula DAP and do it outside.
thetragichero
Re: Tolex glue
Post by thetragichero »
Re: Tolex glue
For small jobs, like doing a cabinet or two, I like 3M 77 spray. I had a hard time with proper application of the stuff in the can and the jobs I did with it are peeling at the edges. One day, I will peel them, scrape them down and do them again. If you search here, you'll probably find some old threads on this topic.
Doug R.
Re: Tolex glue
Post by Doug R. »
I sold solvent based adhesives for a living for 30 years. I used a spray contact cement, similar to auto trim cement and a spray gun. You can also use a brush grade contact cement taking care not to put a heavy coating on the tolex. Allow drying time, AKA open tome, for the solvent to dissipate before putting the cover on...Apprx 10-15 minutes. You can easily trap solvent which causes bubbles.
